1 members (MowingManiac), 3,610 guests, and 1,380 robots.
#102773 08/01/20 06:10 PM
Hi everyone
The quest toward the back of the overfull shed continues. I came across the Honda HRU19D deck I picked up with handles, blade plate, catcher and fuel tank off the curb a few months ago.
My original idea when I got it out of the shed was to sell it, but then I spotted something else. My rusty Victa tornado 300 with v40 Chonda and I had a think.
Blasphemy I know, but would a OHV Chonda knock off fit on a deck designed for an OHC Honda?
And what about shaft length? I think it should as they had to use the height ring on standard 18 inch decks.
Also, I have got the 19 inch 4 blade carrier on the victa as well - considering the Honda deck is also 19 inch (assuming that's what the 19 in the model number means) will it fit and cut at the right height?
Will have a bit of a play around with it and see how it goes - worst case I just need to buy a honda blade boss as I already have the blade plate
Tyler #102776 08/01/20 06:55 PM
Hi Tyler,
Lots of questions there and there is never a one piece fits all answer. The Chonda will bolt on, will it be the same cutting height, that depends on the offset in the blade carrier, some are deeper dished than others so this can vary the height of the blades up inside the body. I have not looked at what can be done to fit a Honda blade carrier to a Chonda one, it can be done but I'm sure it will require a lathe to get it centered up. The Hondas I have played with all seem to have the same diameter blade carrier but use longer blades to become the 19 inch. The Hondas and Chondas have the 22mm blade carrier which puts another problem in the boss mix. I have had to turn out the Honda bosses to fit the Briggs shafts so I can use the smaller diameter Honda blade carriers on the 16 inch mowers I have been putting together recently
Tyler #102777 08/01/20 07:36 PM
Hi Norm & Tyler,
From my own experience and as you (Norm) are aware I changed Honda engines, taking one from a Victa and putting it on the Honda Chassis as the original Honda OHC engine (GCV-160) smoked like a train.
To my surprise I noticed that I couldn't use the Honda Blade carrier as the original Genuine Honda engine uses a 25mm diameter shaft while the GCV-160 Honda's used for Victa's had a 22mm shaft, thus I had to use the Victa carrier and boss on the Honda chassis. The only issue that seems to be is that the blades don't go right out to the skirt, thus losing a bit of vacuum underneath.
What I'd like to do is have a 1.5mm thick sleeve turned up so that I can use the Honda blade carrier and blades on the same branded machine.
Tyler #102779 08/01/20 07:55 PM
Thanks Norm and BB
Interesting how the shafts differ. I have the 19 inch victa blades on the carrier now, so hopefully they might work
I will have a fiddle late next week and see what I can cobble together (maybe cobble isn't the right word as I don't want to stuff around too much with the working of a component spinning at 2800 rpm with 4 knives attached)
Thanks again
Tyler
Tyler #102783 08/01/20 08:38 PM
And if you really want to go overboard you can always use the blades off a 24, now they are the real deal when talking blades. Bit more expensive at $11/12 a pair though, they go out to 22 inch on the Victa standard blade carrier
Tyler #102784 08/01/20 08:45 PM
Thats good to know Norm
I picked up a pair from an old old hardware store for $5.50 - was planning to see how they fit on my Supaswift big bob 21 inch, but havent got to it yet.
Regards
Tyler
Tyler #102836 10/01/20 06:38 PM
Hi BB,
I may be able to help you with that sleve you need, I will know tomorrow, I have just removed a Suzuki from an Ariens and it obviously had a Briggs on it previously and it has had a sleve fitted to it so the Briggs drive pulley would fit. I am fitting a GXV Honda to it and if that has a 25mm shaft I won't need the sleve, that is if I can get it off
Tyler #102838 10/01/20 08:17 PM
Wow thanks, I never knew that someone else would have had one made or even better that it was made so as to suit a batch of engines to a boss that was a current production item.
I think you'll find that all the GXV-160's had a 25mm output shaft diameter if it was fitted to a Honda originally. It seems only when the Honda engines were made for OEM fitment for third parties such as Victa etc. that they made them with the same size shaft as their competition, such as Briggs etc.
Tyler #102841 10/01/20 08:33 PM
BB
somebody has had this made, it wasn't for the boss it was made so they could run the Briggs pulley on the 22 mm shaft. It is about 40mm long, just have to be able to get it off without damaging it.
Tyler #102847 10/01/20 09:05 PM
Yep got it.
I have complete faith in you Norm, failure is not an option from where you sit.
Tyler #102848 10/01/20 11:45 PM
Honda's are boring engines to use. They don't even feel good to pull start. They are the Toyota Camry of mower power plants, functional but lacking character.
Tyler #102853 11/01/20 06:51 AM
MF,
to most people mowing the lawn is boring and most don't give a toss about what a motor feels like, all they want to do is get the lawn cut with as little fuss as possible and for as long as possible. The real Hondas (not the lookalikes) will do this for many many years and if that is boring most people would love to have a boring mower
Tyler #102854 11/01/20 07:29 AM
Couldn't of said it better myself Norm.
It's amazing when folks ask you what your hobby is and one replies with "I enjoy working on Lawnmowers", then most just look at you and simply put their nose up in the air and walk away.
That's the way many think about mowing lawns, to them it is a chore and not an enjoyment and that's why Lawnmowers get treated the way they do and as Norm suggested, Honda's just do it more reliably time and time again.
Your right MF they are no Subaru WRX, rather they're a Falcon Taxi on LPG or as you put it nicely a Toyota Hybrid Camry, quiet and boring.
Tyler #102858 11/01/20 12:56 PM
Hi BB,
this is the sleve it is 25 OD and 22 ID, The Honda shaft is 25 and then steps down to 22 for the boss. Do you recognize the blade carrier, I think it is Masport? If the sleve is good for you what do you suggest we do with it, I'm not paying $8 for Aus Post to rip us blind.
Tyler #102865 11/01/20 04:29 PM
That's exactly what I need and to turn it up would really cost more than the postage, so I guess the consumer is going to pay. The consumer is me so that means I'm going to have to pay what it's going to cost. I wouldn't have it any other way. For small stuff like this AP is the only choice, but with larger items AP is a total rip and as such I'll never use them for that sort of stuff.
I just sent a box that's 550mm x 260mm x 300mm and weighed in at 3 Kg to Melbourne (Pakenham) via a courier company and it cost me $18.00. Now for the same sizing via AP it would've been around the mid $40's. So in that instance AP is way outside the ball park, but for small padded bag stuff they are in their own league. I guess it's all about what the contents are worth to who ?
I'll give you a call as we really shouldn't be boring all the readers with our personal stuff LOL !
PS. Yes it's a Masport Carrier.
Tyler #102939 14/01/20 02:31 PM
Ned Kelly is alive and well in Australia getting around under the name of Aus Post, I asked my wife to post this sleve to BB probably weighs 10 grams and she came back with the docket for $10.05, I will never ever post anything ever again using those thieving mongrels.
Tyler #102942 14/01/20 06:22 PM
I must admit I grapple to comprehend how they can extort such exorbitant prices when I can send a large box with two large tail lights inside for $18.00 via a Courier from Adelaide to Melbourne.
The large box was picked up from my home last Thursday and it arrived delivered to the customers door yesterday. Now you couldn't complain with that, but $10 plus for a small padded bag, that's daylight robbery.
Tyler #102943 14/01/20 07:21 PM
BB, I will never ever send even a letter ever again with that pack of thieving bastards, I should have taken it to the Post office myself because then I could have given them the biggest mouthful and just walked out and thrown the sleeve in the bin. Never again will they catch me ever.
Tyler #103032 18/01/20 07:42 PM
Well after bucket loads of emery rubbing internally I've finally managed to fit the sleeve to the Honda snuggly and now the original blade carrier is fitted. One thing I still need to do and that is replace the key steel that's locks the boss to the crank with a wider size as the sleeve doesn't allow correct protrusion into the keyway of the crank. So I've ordered a piece from CBC Bearings as good ol' South Australia can't keep anything in stock and it's got to come out of where else ? but Melbourne...........of course.
Anyway I still have to procure a set of 4 new blades to fit but once these normal things are done then that'll be it and good happy mowing of everyone else's gardens that I do with a conventional mower is concerned.
Once again a huge thank you to Norm who helped out with the sleeve. You're an absolute Champion.
NormK #103036 18/01/20 08:41 PM
Originally Posted by NormK
Hi BB,
loooks like a masport quad cut carrier. and ive got a couple of questions on it if you dont mind. how thick is the steel its pressed from? whats the size of the centre hole? and how high do the blades sit relative to the height of the shaft mounting point?
been looking at adapting a pair onto my 40" murray ride on cos bar blades suck. i had semi successfully adapted a set of victa mulching discs with trimmed super 24 blades but the pressed profile of the victa disc lowered the blade height below the edge of the deck resulting in bad scalping on any sort of bump. basically looking for a carrier and swing blade setup that is as close to flat as possible to keep blade height near to std as possible, and ideally as close to 512mm dia as possible( masport 20 quad cut lists as 515mm)
Tyler #103040 18/01/20 09:33 PM
All good BB, hope it does the job for you, regardless of what Aus Post does to us.
Hi Billy,
That is a tough one, not going to be easy to get around it, The Masport one I can measure in the morning but I think the offset will be very similar to the Victa one. I'm thinking you may have to get these laser cut from 5mm plate and they can easily cut the holes with the ears in them to suit the Victa blades. What sort of boss did you fit, the spindles would have been much bigger that the Briggs 7/8th boss. You are right, bar blades suck. Thinking about it I wonder if I could put the Victa carrier in my press and press the boss center so it comes down flush with where the blades sit. I think it could be done, I will try one tomorrow see how it goes
Tyler #103041 18/01/20 09:40 PM
didnt fit any boss, just drilled the victa discs to the same size centre hole as the bar blade which was 7/8th andd fitted with the standard murray centering washers
it actually worked quite well as far as a much better cut and cleared the cut grass out the chute much bettter but the mulching discs seemed to cause a bit of vibration but that was probly a blade trimming issue
Tyler #103043 18/01/20 09:45 PM
Ok so what are your thoughts on pressing the center down
Tyler #103044 18/01/20 09:53 PM
possibly worth a go, ive already got the discs with drilled centers sitting here so nothing to loose
Tyler #103045 18/01/20 10:00 PM
I will press one down in the morning to see how it goes, it only has to go down about 30mm so that would lift your blades 30mm
Tyler #103051 19/01/20 09:59 AM
Hi Billyj
That was super easy, short piece of 2 inch pipe and press it down. I used an oval one because I have bucket loads of those but the round ones will press down just as easily.
Tyler #103060 19/01/20 11:43 AM
Cheers norm. Ill have to look at getting these 2 pressed when i get a chance. Looks like it will work nicely
Tyler #103061 19/01/20 12:02 PM
Pity you are so far away because it only takes a few mins
Tyler #103245 28/01/20 04:25 PM
Well after finally receiving my Honda Blades today and fitting them I can confidently say that my Honda is finally complete and running as it should with a blade to skirt clearance of about 7mm which will provide much better suction than the under sized Victa Blade Carrier that had about 30mm clearance.
Tyler #103246 28/01/20 04:33 PM
So how do you think this one I was working on today would work, a 19 inch Tornado fitted with only 2 18 inch blades. He did say it didn't seem to be working very well
18,147 Registered Users
Members18,148
