0 members (), 6,738 guests, and 1,629 robots.
by Bruce - 01/11/26 10:58 PM
#101704 09/11/19 10:58 AM
This has probably been discussed in depth here somewhere but can anybody tell me how this gear is removed. I believe the nut will be threaded and I'm guessing it should be a right hand thread but it doesn't seem to want to move. Any advice appreciated and will make Phil happy.
NormK #101707 09/11/19 06:09 PM
G'day Norm
I can't quite see which sprocket this is.
If it's the rear roller sprocket, and there is no key-way, it will be
a LH thread. If there is a key-way, it will be RH.
Hope this helps
NormK #101710 09/11/19 10:21 PM
Hi Jack,
Thanks for that, it is the roller drive sprocket, there is a keyway there but I haven't seen the rest of it so I'm not sure how it all works. Tightening RH seems to be locking the sprocket up, LH does loosen the sprocket a little so it allows the sprocket to spin but that is all I have been able to achieve.
NormK #101715 10/11/19 11:57 AM
G'day Norm
LH threads are only used if there is an engineering purpose.
I now suspect that rear roller sprocket tells another story.
If there is a landroll clutch (two clutches on the mower),
then that would explain a LH thread on the roller.
My guess is that a dog clutch (within the chaincase) acts
on this sprocket. This has been removed (in your image).
When free-rolling (disengaged), a LH thread would be needed
to stop the sprocket from undoing.
These are just thoughts - as I have no parts list for the A-V.
But I do have a hint - from an old eBay sale ...
NormK #101720 10/11/19 01:54 PM
Austral villiers sprocket removal
Norm and Jack..
Am hoping to put another photo up which may
or may not help provide an answer
Phil
NormK #101721 10/11/19 02:03 PM
Hello Seafordphil
That image helps a lot!
It does confirm a secondary clutch on this A-V.
My best guess is that this dog clutch was secured by
a regular RH bolt (bottom right), but the sprocket nut had accordingly
a left hand thread to prevent unscrewing in disengaged mode.
Maybe ...
Nothing is certain here, but I feel Norm will help
others in understanding the A-V final drive.
I wish I had the answer, but information is scarce.
NormK #101749 11/11/19 07:43 AM
Hi Jack,
Thanks again for your help, as I only have what you can see in the first pic it is a little hard for me to understand how the drive actually worked, but hopefully we will get it sorted out.
NormK #101770 12/11/19 09:53 AM
Hi Phil,
What do you think our next move should be, my 1150nm rattle gun is not making any impression on it.
NormK #101806 13/11/19 09:27 PM
A Thank you to Norm
Sprocket removed,several other problems solved.
Can highly recommend if needed.
Thanks again Norm
PHIL
NormK #101812 14/11/19 08:17 AM
Hi Phil,
I was thinking about it last night and my son could turn up a wooden rear roller to fit inside your existing drum to strengthen it up. Just a thought.
18,199 Registered Users
Topics12,770
Posts106,858
Members18,201
