0 members (), 6,981 guests, and 1,680 robots.
Gday fellas,
I have been tearing down a victa imperial to give it some love and a new lick of paint.
All I need to do now is take the clutch apart. I have the clutch in two pieces with the pads exposed but am unsure how to remove them. I am leaning towards they are blind riveted on.
Which is fine as I run a blacksmith shop and can easily put new ones in, I just want to make sure before I remove them and do damage.
https://share.icloud.com/photos/0a8fVCxLoyiIM6bCt7Njcvpaw[/img]
https://share.icloud.com/photos/0z2Cu65VjjGEg9Fdb_CSGir7w[/img]
Hello POI
My best guess is that these are solid rivets (not blind).
The peening marks are clearly visible.
[I note that the Imperial also used solid rivets for the bottom blade].
Please keep us informed as your works may well help others.
I'm guessing you intend to replace the clutch linings?
Yes that is kinda what I was getting at.
The bottom blade has both top and bottom rivet exposed. Where in this case I am almost certain there is only a head on these rivets which I think they are pressed in and its more of a friction fit.
I only want to take it apart to sand blast and give a coat of paint.
G'day POI
Yes, I think that too.
Mild steel rod pressed in as an interference fit,
then peened over.
I guess length will be critical for peening.
Any info and images of the process will be most welcome.
Many thanks
Nope we were both wrong.
Turns out they were a kind of bolt. I dont know why they had a proper head on them to undo them easier
18,232 Registered Users
Topics12,777
Posts106,881
Members18,233
