0 members (), 2,533 guests, and 456 robots.
#9761 07/10/08 07:56 AM
Hi.
I am looking for a part for my Mac 15 chainsaw. It is the black plug that goes in the hole over the spark plug. If anyone can help I would appreciate it.
Matt.
[Linked Image from img388.imageshack.us]
[Linked Image from img528.imageshack.us]
Matt #9767 07/10/08 11:33 AM
Matt,
The part number that you are after is 57565 and I don't know if you will be able to locate it unless you can find one second hand. I will ask around but I don't like my chances of finding one. cheers2
Bruce #10081 07/11/08 08:09 AM
Bruce,
I don't know if you can help me again, but I need a carbie kit for my Mac 15, for a Tillotson HC series carb.
Thanks.
Matt.
Matt #10082 07/11/08 09:15 AM
Matt,
Can you give me some more information on the carby (an numbers that are stamped on it) so that I can get you the correct kit. cheers2
Bruce #10085 07/11/08 10:16 AM
Bruce,
carby has no numbers at all on the outside. It has the number 40 on the air inlet behind the choke butterfly. If this helps the choke butterfly has the numbers 62-36 and the throttle butterfly the numbers 34-46. I have been doing some research on Mac 15 chainsaws and I think they were fitted with a Tillotson HC-13A carby.
Thanks.
Matt.
Matt #10094 08/11/08 01:04 PM
Matt,
Can you post a couple of pictures as the Mac 15 chainsaw has a couple of different types of carby depending on what year it was made but do not show the brand only a part number.
Once I see the carby I will have a better idea of the kit required. cheers2
Bruce #10098 09/11/08 03:02 AM
Bruce. Here are photos of carb.
[Linked Image from img293.imageshack.us]
[Linked Image from img116.imageshack.us]
[Linked Image from img84.imageshack.us]
Thanks.
Matt.
Matt #10109 10/11/08 02:37 PM
Bruce.
Found numbers on body under needle/seat cover.
I hope this helps.
Thanks.
Matt.
Matt #10162 14/11/08 04:04 AM
Matt,
I can not locate any HC kits but it looks like a HS type carby. Even the website does not list that model carby.
I do have the HS kit in stock but can't be 100% sure that it is correct as I need a measurement of the metering stem. cheers2
Bruce #10164 14/11/08 01:05 PM
Bruce, when you say metering stem are you refering to the high speed adjusting screw??
Matt.
Matt #10175 15/11/08 01:20 PM
Thanks.
Matt.
Matt.
If you look at the second pic and undo the 4 screws, then measure the metal plunger depth I will be able to compare with the kit that I have. cheers2
Bruce #10177 16/11/08 01:59 AM
Bruce.
Plunger depth is 2.5mm.
I have been looking into the HC carb again and a few guys say it is a HL carb without the fuel pump???
Dont know if this is so but just a thought.
An exploded view of a HS looks the same though which is what you said.
http://www.acresinternet.com/cscc.n...739e3628dc088256e0f007adaac?OpenDocument
Thanks again.
Matt.
Matt #10242 21/11/08 10:42 AM
Any luck Bruce?
Matt #10247 22/11/08 01:00 AM
Matt,
Below is a HL Kit Picture which I would have to order in as I don't have one in stock.
HL Kit.jpg (0 Bytes, 133 downloads)
HL Carby Kit
Bruce #10249 22/11/08 01:07 AM
Hate to tell you guys but the picture is not a hl kit it is in fact a hs. HC carbys were also used on some outboards
Sometimes stuff just happens (usually to me)
mowerman666 #10256 22/11/08 05:35 AM
Chainsaw Addict
Yes that's the same HS Carby Kit I fitted to my Pioneer 3270 a couple of months ago
Moderated by  Bruce, Mr Davis
18,144 Registered Users
Members18,145
