0 members (), 4,609 guests, and 344 robots.
#100844 13/09/19 08:11 PM
I just noticed they finally relocated the handle mounting points to the side. It's a shame they deleted the raised PT hole and the cut out for the exhaust.
I wonder if you can drill a hole and use washers to mount the PT when the B&S eventually fails?
Word is that they altered the base because the new plastic briggs carby linkages were getting clogged with dirt being thrown out around the spacer - apparently really stuffing up the readystarts.
Notice no ring now I believe
That means you need to find a PT with the longer shaft, which are much less common.
Bonnar_Bloke that reflects your well known sentiments in this!
MF,
When the PT bases are all gone that is the end of it, too difficult to try mounting a PT on the other bases and in case you hadn't noticed they have removed the dip in the height adjuster bar so this makes these bases no more difficult to mount a PT on than any of the 4 stroke bases kicking around now. It is too difficult to mount a PT motor in the north south direction on these bases
Moderated by  Bruce, Deejay
18,154 Registered Users
Members18,156
