1 members (Buckets), 4,658 guests, and 1,711 robots.
#9605 26/09/08 07:47 AM
Hi,
I have a PLT3043A 2 cycle line trimmer with a jammed starter cord.
I started to dismantle by easing the four screws that hold the shaft section to the motor block - suddenly the cord rewound normally. Jammed again once screws retightened and attempted to start. The starter mechanism engages with two small spring loaded hinged "catches"? on the housing mounted on the end of the crank shaft. The plastic Gear? on the starter is damaged with several lugs cut by the catches on the housing.
As you can tell from the above description my knowledge of small motors is limited. I would really appreciate some help.
Do the catches act as a sort of clutch to disengage the starter once the engine starts?
Is there a clutch in the housing - if so how can it be checked/changed.
Is it possible to get a copy of a service manual that shows how it all works.
I have the same problem, looks as though one the springs have broken on mine which did not disengage the plastic gear, thus stripping the cog. Mine had only been used a few times and has been sitting in my shed for the 2 years or so. Disappointed. Impossiable to track down parts. It is more viable to buy a new unit rather than have a service centre fix it.
A few on ebay, really cheap.
I found one of these in the 'junk collection'.
EXACTLY the same problem - the plastic starter cog has been stripped by the metal catches.
There's no broken springs in mine - I suspect a manufacturing design flaw wink designed for obsolence??
Anyway - how to fix this one?
18,147 Registered Users
Members18,148
