3 members (MowingManiac, DFB, Red Rum), 1,656 guests, and 570 robots.
Victa 24 engine pulleys
by NormK - 19/10/25 08:49 PM
Re rotomo crankshaft.
Rotomo crank shaft
Oregon corded chain saw
by NormK - 05/10/25 11:12 AM
Out there cutting again.
by MowingManiac - 22/10/25 08:38 PM
The Rover Pro-Cut Chronicles
by DFB - 19/10/25 09:36 PM
by NormK - 17/10/25 08:56 PM
Rotomo crank shaft
Previous Gallery
Next Gallery
#10541 16/12/08 06:10 AM
2 Images
Chainsaw Addict
Olympk 284F
Built by Oleo Mac in 1988 84cc needs a new piston and cylinder,I have one on the way from the US.
cheers gmax
8 Comments
gmax #10553 16/12/08 02:48 PM
Gmax,
What sort of cost as I am sure that it is available here in OZ. cheers2
Bruce #10559 16/12/08 03:15 PM
Chainsaw Addict
Bruce,
$143.00 for piston cylinder and rings, that's for used parts in good condition.
cheers gmax
gmax #10742 31/12/08 10:18 AM
Chainsaw Addict
Bruce,
The piston cylinder and rings arrived today but the cylinder is different to mine banghead.
If the seller dosen't have another one I might see if you can get one, I guess a Olympic 284 & Olympk 284 F are different?.
That's news to me.
Photobucket
cheers gmax
gmax #10759 02/01/09 05:46 PM
gmax,
The part numbers that you need are as follows:
Cylinder 008100001
Piston Assy 008200521
Bruce #10760 02/01/09 06:10 PM
Chainsaw Addict
Bruce,
Thanks, I'm getting the correct cylinder from the US, I will
be using the piston that came with the wrong cylinder. So after all this mucking around it had better run.. LOL.
Bruce I will need a cylinder gasket, could you let me know if
you can supply one, thanks
cheers gmax
gmax #10853 10/01/09 10:52 AM
Chainsaw Addict
The Olympk is all finished, I used a new cylinder with a good used piston, It runs like new again, 81cc it will be a fun firewood saw to use. Photobucket cheers gmax
gmax #45844 14/05/13 10:29 AM
Hi Gmax, Looking at the forum for your repairs to your Oleo-Mac 284 or 284F. Not sure which one you had. We have a Oleo-Mac 284F which has broken rings. The cylinder/barrel and piston if fine, all we need is the rings. Do you have any idea where we could buy the rings. Maybe Bruce would know and if so how do I get in contact with him. Thanks Rosemary48 :)
gmax #45847 14/05/13 11:26 AM
Rosemary, that thread hasn't had a post in more than 3 years, and it has been a couple of years since gmax visited this site. If you are going to contact him, your best chance would be at aboristsite.com, but I'm not sure he's been there in years either.
Bruce is the Outdoorking site owner, as well as being a dealer in outdoor equipment. You can contact him by sending him a Private Message. At the top of this page you'll find a button marked My Stuff. If you press it, you'll see a drop-down list, beginning with Messages. Press that button. Then click the New Private Message button. Type Bruce in the Add Recipient window. Right below that, type your message title in the Subject window, and the details of what you want in the Message window right below that. Press Submit when you have completed your question.
If not even Bruce can find you the piston rings, there is still the possibility of doing it the hard way. Because your piston is still good, all you need is a set of 2 stroke piston rings that are the right diameter (to fit the cylinder bore), the right depth (so they don't hit the bottom of the piston's ring grooves) and the right width (so they are a close fit across the width of the piston's ring grooves). You will need to do some exact measuring on the old piston rings you have, then post the dimensions here, as well as trying a chainsaw dealer or two.
Moderated by  Bruce, Mr Davis
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29 30 31
Maudebs, Greenarrow01, stkarl, Stannyboy, yaapeet30
17,640 Registered Users
Topics13,009
Posts106,970
Members17,640
PHP: 8.3.26 Page Time: 0.028s Queries: 40 (0.021s) Memory: 0.6697 MB (Peak: 0.7458 MB) Data Comp: Zlib Server Time: 2025-10-22 09:51:41 UTC
