1 members (Widget), 12,766 guests, and 124 robots.
#116541 03/11/22 12:26 AM
I have a B&S 17.5 hp twin cylinder riding lawn mower that I cannot start because the starter cannot overcome the engine's compression stroke. I suspect the compression release valve and loose valve clearances but I cannot find where to adjust. I have removed a small plate to expose valve stems but no adjustment. Help?
Unfortunately if the release has gone (and its one of their common downfalls) its on the cam gear - ie you have to tear the motor down to put in a new camshaft/gear assembly.
Hopefully its just the valve clearances too loose.
for starters, could you please post a couple photos of the motor and the model type code number. it could be on top of one of the valve cover (if its OHV which I hope it is) or somewhere on the metal cowl (if its one of the old opposed boxer motors)
If I was stuck with this situation I would be seeing if I could fit a PT decomp valve to each cylinder Bitch of a job but better than stripping the motor down. Are you sure the battery and starter motor are in good condition?
Tryerb, RobHam, Mark Tasmania, Mello Mac, beanbandit
18,235 Registered Users
Topics12,778
Posts106,882
Members18,236
