2 members (Dandare, 1 invisible), 1,648 guests, and 1,248 robots.
Victa 24 engine pulleys
by NormK - 19/10/25 08:49 PM
Re rotomo crankshaft.
Rotomo crank shaft
Oregon corded chain saw
by NormK - 05/10/25 11:12 AM
Out there cutting again.
by NormK - 22/10/25 09:06 PM
The Rover Pro-Cut Chronicles
by DFB - 19/10/25 09:36 PM
by NormK - 17/10/25 08:56 PM
Rotomo crank shaft
Hi,
I have a Kirby Tecumseh engine which I think is a H25, Unfortunately I can’t find any engine numbers or model numbers.
I’m currently refurbing a Scott Bonner 33 and want to freshen up the Kirby motor, Can anyone help me out with which model it is so I can order the correct parts needed.
Parts needed:-
Engine gasket kit.
Bearing.
Front and rear engine seals.
Carby rebuild kit.
New muffler assembly.
Con rod.
Ring set.
Also can you still get the black rubber hose that I'm assuming is crank vent / breather tube?
I will attach some photos for reference.
Much appreciated Damo
Hi Damo S, welcome to our Forum.
Not sure about your parts availability, bearings and seals will be fine from any bearing shop. Gasket set should be ok but conrod might be an ask. The hose is available but dear at between $20-$30. I will find a link for you soon.
https://www.outdoorking-forum.com.au/engines...ngine-parts/tecumseh-breather-tube-37591
There is another recent thread of a similar rebuild which should benefit you, I will post it here for you shortly.
https://www.outdoorking-forum.com.au/forum/u.../kirby-h4-4a-tecumseh-hk25-re-build.html
https://www.outdoorking-forum.com.au/forum/ubbthreads.php/topics/37736/kirby-h4-4a-engine-rebuild.html
Hi Damo S
I have attached a Tecumseh parts identification broucher that lists models, part numbers and pictures, once you can identify the parts you need just do a google or eBay search on those numbers and see what comes up, the sad part is the parts will be available in the U.S and shipping will burn you if you need a few parts from different suppliers, if you desperately just need 1 or 2 parts you might bite the bullet and pay it but for a handfull of parts you would be better off waiting for another engine to pop up cheap and use it for parts.
Gasket kits are cheap and not a problem to source, just make sure you measure the PTO seal as I believe some same models came with 2 different shaft sizes i.e 2 different seal sizes
Good luck.
BS
I've got a highway to mow
Thank you Paul C and Bon Scott for the replys and also for the above information and help, will try my luck finding the required parts needed for my rebuild.
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29 30 31
Maudebs, Greenarrow01, stkarl, Stannyboy, yaapeet30
17,640 Registered Users
Topics13,009
Posts106,971
Members17,640
PHP: 8.3.26 Page Time: 0.061s Queries: 25 (0.055s) Memory: 0.6363 MB (Peak: 0.6786 MB) Data Comp: Zlib Server Time: 2025-10-23 03:43:03 UTC
