3 members (ASample, Peter1162, leslloyd), 1,114 guests, and 704 robots.
by NormK - 01/12/25 05:15 PM
by NormK - 09/12/25 09:14 AM
Victa 24 with PT fitted
by NormK - 05/12/25 09:55 PM
Lectron Generator Fuel Pump
Page 2 of 3 1 2 3
Hello paul_c,
what a transformation. Looks like you nailed the colour and great close up pic showing us the finish.
Well done obtaining the cover plate too.
Thanks Mowerfreak,
I reckon you could get a better result from the hammered finish by using a brush. I had some left over thinned paint and using a brush I painted a piece of flat tin and it came up great.
Hello ODK members,
A fine sunny day here in Brisbane so I gave the cowl and starter a coat of paint, looks not to bad at all.
Looking good paul c,
that's a beautiful hammertone.
Hi Mowerfreak,
To be honest it looks nice being fresh paint and all but the colour is a bit flat, there seems to be none of the mottling like I got with the base colour. The dimple is good for hiding flaws though.
Hmm, I see what you mean. Looks like you need to add additional coats and experiment. Does anyone know what is wrong?
Just the way it is
Greenfield Hoarder
Evening members!
Paul, Could it be an old can that you've used?
Was this sprayed or brushed on?
- Blended
I thought I read somewhere on ODK that with hammertone paint to get a awesome
finish you spray light mist coats then let it dry a little then repeat.
Max
Greenfield Hoarder
Max
Hey all,
Max, i thought the opposite? Apply wet for a better finish?
I could be wrong in saying this, I've only ever used it for small jobs, not large surface areas.
- Blended
Hi Blended and all
Start with a mist coat (light coat) If your first coat is a wet coat, you'll get runs and sags. So you mist on a base layer of paint with coats that aren't heavy enough to get glossy, then make it pretty with the last one.
https://www.outdoorking-forum.com.au/forum/ubbthreads.php/topics/81450/Tips_for_getting_a_good_hammer.html
Max
Hello ODK Members,
Paint sure is an art to get right. Thanks for the link there Max, anyway moving on. Fitted up the axles after cleaning and fitting in a new set of bushes. It had some axle slot repairs done previous so I guess that's when the bushes were first fitted. No issues painting up the exhaust in heat resistant black and I just placed the cowl on to see how the colours looked together.
Next little job is to make a new bracket for the air cleaner and then it can be painted as well, I was lucky enough to find a new old stock air cleaner hose for it.
wce Offline
Hi Paul and all
Paintwork looks terrific ! and a nice tidy shed. Wynn's sticker in the background brings back memories of the old days. Looking forward to the progressive pictures.
wce
Will we get to hear it? It must sound better than the modern Victas.
Hi ODK Members,
It will run and cut grass Mowerfreak, pulled down the engine to have a look. Had a seized up top bearing but someone had replaced the bottom bearings and seal, a bit of a make do repair on the piston groove to retain the ring. I will fit another 20 over piston and new rings, bore is good so just a hone.
Hello All,
Nearly back together :-)
Coming along nicely paul_c. Beautiful engine the 125cc.
Good Morning ODK Members,
An update on progress, the last of the parts were painted and look great. I opted for Brunswick Green for the bars, originally chromed but the only option was silver paint and having done that before it just doesn’t work for me.
The bars were a real mess, seized broken /bolts rusted through rods, missing springs and of course more rust. Drilled out the sheared bolts and recapped them, found some donor parts from the later Corvette that with machining will work and using a shortened click rod all will be good.
Picked up a blade plate with new thrower blades on it which will be fitted onto my nice painted one. I was surprised at how bent over the blade is to enable enough air to move the grass into the catcher.
G'day Paul
Many thanks for the brilliant images.
This really does add to the record of these forgotten Victas.
For me, the highlight must be your record of the base and chassis.
These have not been that well recorded.
Paul, your topic has added to my appreciation of the Viceroy.
It had so many Victa firsts - the two-tone paint job, double-fold handle,
new cad plated axles, 'turboflo' blades!
https://www.outdoorking-forum.com.au/forum/ubbthreads.php/topics/70039/model-viceroy-1962-63.html
And of course, this topic adds to the provenance of this particular machine.
Good Evening ODK Members,
After making up the top click rod for the bars this morning they are together again 😀
Page 2 of 3 1 2 3
17,714 Registered Users
Topics13,031
Posts107,112
Members17,715
PHP: 8.3.27 Page Time: 0.088s Queries: 62 (0.078s) Memory: 0.7366 MB (Peak: 0.8494 MB) Data Comp: Zlib Server Time: 2025-12-10 06:19:57 UTC
