0 members (), 1,027 guests, and 1,038 robots.
My Hyundai Mower is surging.
by aLaw13 - 20/04/26 01:29 AM
Rover height adjust plate
by Bruce - 07/04/26 03:39 PM
Atom Spare Parts For Sale
by Bruce - 07/04/26 03:24 PM
Ryobi Spare Parts
by Bruce - 07/04/26 12:00 PM
YardKing 4 stroke spare parts
Ryobi Spare Parts
wce #98507 08/05/19 06:03 PM
Hello again wce
I can't really add any more to my previous post and what others have said, but can confirm again, from my records, your serial number and photos it is a Mayfair 68-69 Deluxe 2 Model 559 (Victacode V76), it does have the correct chassis base and a G2 Carburettor.The catcher is listed as a model 15 and is plastic.
Although, I would be interested to know where the white extension cable goes? I'm not familiar with this model, but it looks like a cut out switch lead (for magneto earthing), others may wish to comment on this.
Mark
wce #98509 08/05/19 09:46 PM
G'day MarkN, Max, Gadge, and all contributors.
Many thanks to Gadge, Max and Mark for the expert information
presented here.
This is the thing I do not understand ...
The G2 carby had a short production life ... was it just one season?
As a revolutionary step in Victa engines, where is the advertising?
In the manual for the 1968-69 year there is scant reference and
no illustration of the carby! Why is this?
https://www.outdoorking-forum.com.au/forum/ubbthreads.php/topics/84468/manual-new-victa-mowers-1968-69.html
This was Victa's first governed 2-stroke, and I guess it was more
complex - and expensive to make and assemble - than need have been...
It is as though Victa knew this. The remote wire and cut-out (linked to throttle)
required more parts and longer assembly time. The metal flag gov vane may
have been less responsive (but I have no info there).
What is true, is that the next year (and decade) ushered in the G3 carby, a
much loved,compact and reliable design (when set to specification).
More plastics were used, the now plastic gov vane was adjustable,
(not by a spring but a clever rotary tooth gear) and cut-out was
brought onboard the carby itself.
looking at Victa publications, it is as though Victa wanted the G2
to disappear... A bit like the Predicta from the previous decade ...
I'm sure the experts will have an opinion on the quick change -
from G2 to G3...
wce #98513 09/05/19 12:48 AM
Gidday Jack and all,
One problem with the G2 carby was the lack of adequate sealing of the butterfly spindle in contaminated
air conditions.
The G2 Carby doesn't have both sides of the butterfly spindle sealed off to the outside contaminated air.
The G3 superseded this design flaw by sealing off both ends of the butterfly spindle (the G2 only had one end sealed)
The red circle shows the spindle plug for the updated G3 carby in the image below.
The G3 patent was lodged on the 31st of March 1970 so the G2 was used for more than 12 months.
I would say the throttle control was improved with the G3 carby looking at the two different designs.
Not sure why there was scant reference to the G2 carby in the 68/69 manual.
Every mower I've had that should have a G2 was retrofitted with the G3 so I can't report on other
bad characteristics other than the ones I have mentioned.
A few Inventors names listed on the below patents.
G'day folks,
There are a few asked questions to cover here, so I'll address them in posted order.
WCE, as has been said, the fitted carby on your Mayfair is indeed a rare G2 [well spotted, MarkN], and the spare is a complete G3 assembly [carby, cable and throttle control].
The non-serviceable air filter unit was a short-lived Victa idea of that time, and was usually replaced by the serviceable AF07381A short filter unit when a machine came in for service. The non-serviceable unit was a PITA, as there was no simple way of checking the element condition.
The only external difference in the housings, is that the AF07381A has a tab on the cap, making it easy to pop off.
MarkN, the white cable is indeed the cutout switch lead. These G2 models were the first series of 2-stroke Victas to have this feature.
The lead runs from the magneto to the throttle control on the handle, within a plastic sleeve that also covers the throttle cable. At the top end, the cutout lead connects to a brass terminal strip riveted to the plastic filter housing, and the steel throttle lever performs the switch function.
CyberJack, maybe Victa just didn't think that the governed engine made that much difference, to the operator of the machine! And yes, the G2 was very short-lived; the 1969 season for sure, and maybe part/all of the 1970 one.
As for advertising, the G2 is mentioned and shown in the 1969 season brochure; https://www.outdoorking-forum.com.au/forum/ubbthreads.php/topics/77945/brochure-1968-69-range.html
The 1970 season brochure is a bit ambivalent; the carby pic shows a G2, but the Series 70 cutaway engine pic and photo clearly show the G3! And the 'G3' designation is mentioned in the text. https://www.outdoorking-forum.com.au/forum/ubbthreads.php/topics/75923/catalogue-victa-1970-range.html
Maxwestern, the other major issue I recall seeing in G2's, was wear in the bore that the stem of the relatively heavy metal governor vane passes through. Once that was worn, the governor gears would slip a tooth or two, and throw out the governor adjustment.
It wasn't worth rebuilding a G2 with a worn body even back in the day; the swap to a new G3 and G3 throttle cable was cheaper and much easier.
The stop switch lead just needed shortening a bit [allowing for a loose turn around the 'flag pole' to reduce flexing] , and crimping on a female spade terminal.
As far as introduction dates go, for the G2, Victa's Servicing Guide No. 63 was issued in September 1968, which aligns with the 1968-9 season brochure. https://www.outdoorking-forum.com.au/forum/ubbthreads.php/topics/58949/victa-service-guides-1960s.html
Unfortunately we don't seem to have the equivalent Tech Bulletin for the G3 here at ODK.
wce #98524 09/05/19 06:59 PM
It's important to restore a G2 back to operating condition even if it's like keeping a British Leyland built car on the road, for historic purposes (and the challenge).
NormK had been modifying his LM cut out switch to operate similar to the troublesome but interesting G2 setup.
wce #98528 09/05/19 07:23 PM
Yes MF, and I am very happy with the cut out switch wire up inside the snorkel, little bit time consuming but once set up works perfectly and never gives any problems, probably done 20 of them that way now and not one problem
wce #98529 09/05/19 07:31 PM
If only you could say that about the LM carby itself. One day maybe, one day lol.
Gadge #98532 09/05/19 08:26 PM
Thanks Gadge for the G2 info. that makes sense that the governor flag spindle wears the bore then
strips out the gears as I collected a couple of G2 carbies and both are very worn and the gears don't engage.
Never seen a good working G2.
G4 late 1975 for the 1976 Range.
Max
wce #98534 09/05/19 09:13 PM
So the above means prototypes of the G4 were ready by 1973?
wce #98535 09/05/19 09:14 PM
wce
Offline
Hi Gadge and all
Many thank's for the great post's, the learning curve is heading North.
MarkN Picture confirms the other expert comments, white wire inside the plastic sheath to throttle control. I'm warming to this machine and I think it may have had a kind life. The base is in great order and is one of only 2 or 3 mowers of any type and age that i have come across that has no mulched on grass cuttings under the base.
I guess the real interest for me now is the purpose of the letter box slot in the base.
Was there any issues with fuel vaporization in the carby known in the previous models ? as this slot faces directly at the carby or could it be the reason they mostly got changed to the G3 carbys as they didn't surcumbe to dust, sand, etc wearing out the spindle.
wce
G'day all,
Max
Yep; the advance Tech Bulletin for the introduction came out in May 1975. https://www.outdoorking-forum.com.au/forum/ubbthreads.php?ubb=showflat&Number=38908
wce, the only possible function I can think of for the 'letter box slot' is that of a 'boost air' intake, to improve catching efficiency. It might also tend to reduce adhesion of clippings to the underside of the chassis.
Err, well yeah maybe. The sticking point is finding a G2 body that doesn't have flogged out governor vane and butterfly shaft bores. Fully complete G2's aren't exactly thick on the ground, either.
While boring/rebushing is likely technically feasible, that'd require a very high skill level, and a decent machine shop setup.
Gadge #98555 10/05/19 10:07 PM
There was good reason the G3 came out when it did and remained as long as it did. The plastic carby that became the G4 was probably already planned when the G3 came out.
17,929 Registered Users
Topics13,084
Posts107,367
Members17,929
PHP: 8.3.30 Page Time: 0.033s Queries: 43 (0.025s) Memory: 0.6951 MB (Peak: 0.7836 MB) Data Comp: Zlib Server Time: 2026-04-21 21:18:33 UTC
