2 members (Bruce, Dandare), 7,251 guests, and 1,885 robots.
#97839 18/04/19 07:36 AM
I picked up this mower for my Victa collection as it’s the first steel base rear catcher mower that Victa released. Not in a happy state but it came with what was left of its catcher but minus starter, air filter and fitted with the incorrect blade plate and boss.
I have made a start by stripping it down and will now clean and repair as I go.
Greenfield Hoarder
Looks like a great starting point Paul, i look forward to watching your progress on this resto!
- Blended
Stripped down to the bare base and some panel beating done on the front, engine will get a clean and will be stripped down to see what condition it’s in.
I did not know Victa came out with a steel base in the 60s. First I knew.
Hi Mowerfreak and Blended,
Made for the 62/63 season and not big in numbers I believe. There was also the four stroke model called the Ambassador. Not sure if the four stroke also came out on the steel base.
G'day Paul and Mowerfreak
Folks forget that Victa's first rear-catcher mowers had steel bases.
For whatever reason, the idea was short-lived.
It was as though Victa was hedging its bets in 1962-63 ...
Rear catcher models - steel base
Side catcher models - alloy base
For the record, yes, the Ambassador also had a steel base ...
https://www.outdoorking-forum.com.au/forum/ubbthreads.php/topics/70029.html
Many thanks Paul for recording these largely forgotten machines.
1 member likes this: jasontarkus
Good evening Cyberjack, Mowerfreak and Blended,
I couldn’t let this one slip away Jack, engine has been cleaned up and it is the original which is great. Very wet up here at the moment so not much more progress.
G-day Paul_c, CyberJack,
It looks as though a FC 160 from the 60s and 70s will go on here. It would make for an interesting, if not original spec combo.
Morning All,
Base is now in primer, when the sun comes out I can give it a light sand and apply a top coat.
Greenfield Hoarder
Looking great Paul! Base looks fantastic and the motor looks to be clean as.
Should be a mint resto mate. Top job!
- Blended
Just shows how solid a good steel base is when it's made of thick enough steel. The latest ones are just pathetic in comparison.
MF business is business steel costs money, the thinner the steel the better the profit margin, do you think for one reason a manufacturer would care less about the fact their bases rust out in 5/10 years. Making something that will last these days is bad for business
What do you think of this Vicaroy Norm?
G'day Paul and all, grin
Paul, I've got to ask this for the record ...
I know you favour 'sensitive' restoration, preserving the original
patina wherever possible.
I'm guessing, here, it was because the mower was in such a poor state.
You are an experienced collector with an envious collection.
Do you have any advice for new or inexperienced collectors
as to the decision process...
At what point do you decide to go for an extensive restoration, as
opposed to a subtle one?
Hi Jack,
With me it all about how much if any original paint is left on the machine, this one had no original paint anywhere and was in quite a sad state all around. The once chrome bars are very rusty and overpainted with one of the locking bars rusted clean through, the base was dented in badly at the front and repainted plain green with a not so matching orange cowl.
If the machine has good decals but poor paint I will just cosmetically tidy it up and do the mechanical side of things to bring it back to running condition. The ones I love to get are the ones that just need a wash and a service.
Your the man to ask on this Paul. I have a steel deck early 90s Victa with a sound deck but with small surface bubbles covering the deck under the original paint, like a rash. I took to part of it with a wire brush but was not able to eliminate all the bumps under the paint.
Would you just do the best possible and put up with an imperfect but improved surface and mask off what you can, or go to the trouble of stripping the deck of components so it can be done thoroughly, including a wire brush attachment with an angle grinder and phosphoric acid (rust converter) before paint? I already have a pressure pack can of Indian red to go on.
Hi Mowerfreak,
If it’s a keeper I would spray the whole deck, chemical strip, sand etc and then paint.
Hi MF,
I just repainted a deck with about the same rust as your pic,used a poly strip disc,it removed the paint
and rust no problem but if you have a lot of rust you will end up with pitted metal so a spray putty
may be needed to fill the pits.
Nice Viceroy Paul_c , I don't think a lot survived because of rust .
Have seen one steel base the same on a Ambassador.
Hey Paul & Max,
your suggestions have been an enormous help in deciding what to do.
I have ordered a poly disc from EBay.
Love the pics of the brand new four stroke version, particularly nose cone with the car like grill!
Can't wait to see the new paint. Well done getting an early example of a Victa steel deck. Makes me appreciate the modern ones more.
Hi ODK members,
Did some painting this afternoon and I’m quite pleased with the result, there is some rain coming and it’s getting cooler so I got the deck painted while the weather was nice. Went to see a mate this morning and came home with a new old stock rear cover plate, what a great find!
Hello paul_c,
what a transformation. Looks like you nailed the colour and great close up pic showing us the finish.
Well done obtaining the cover plate too.
Thanks Mowerfreak,
I reckon you could get a better result from the hammered finish by using a brush. I had some left over thinned paint and using a brush I painted a piece of flat tin and it came up great.
Hello ODK members,
A fine sunny day here in Brisbane so I gave the cowl and starter a coat of paint, looks not to bad at all.
Looking good paul c,
that's a beautiful hammertone.
Hi Mowerfreak,
To be honest it looks nice being fresh paint and all but the colour is a bit flat, there seems to be none of the mottling like I got with the base colour. The dimple is good for hiding flaws though.
Hmm, I see what you mean. Looks like you need to add additional coats and experiment. Does anyone know what is wrong?
Just the way it is
Greenfield Hoarder
Evening members!
Paul, Could it be an old can that you've used?
Was this sprayed or brushed on?
- Blended
I thought I read somewhere on ODK that with hammertone paint to get a awesome
finish you spray light mist coats then let it dry a little then repeat.
Max
Greenfield Hoarder
Max
Hey all,
Max, i thought the opposite? Apply wet for a better finish?
I could be wrong in saying this, I've only ever used it for small jobs, not large surface areas.
- Blended
malo, joemowsbest, greenback, Jett lang, Rover45Restoration
18,207 Registered Users
Topics12,771
Posts106,862
Members18,207
