1 members (Ritcho),
3,484
1,722
Posts: 2,101 Likes: 81
The one you have given the link to on ebay seems fine Widget
I have been handed a few GA Spares Speedfeed heads to install - they seem to go well as well. You just wind them up to install the line, not take apart. The only problem I have had is installing one on a mcculloch (carbon copy of your featherlite). The speedfeeds don't work with trimmers with no clutch.
The thing will run you around $55, for a straight shaft trimmer you need the BRN6923 from memory
Good thing is the replacement end caps (where you bump) only cost around $12 each, and the rest of the body is pretty indestructible
Regards Tyler
Posts: 1,233 Likes: 32
hi Widget, Have you priced the Stihl part? speedy
Regards Tyler Thanks Tyler, Ill look into it :), though at $55, feels a bit steep. The trimmer is only for home use, small-ish property, for just hitting the fence-line. hi Widget, Have you priced the Stihl part? speedy Had a quick look, from what I could find, seem to be similar price as to the Speedfeed head Tyler mentioned. Might be better quality than the cheaper ebay one I linked, but as I would use it once in a while whenever the grass grew, didn't want to spend a whole lot. Anyone have suggestions about those heads that you clip in a piece of string, rather than winding it around the cup ? Can't remember the name... seem like an easier option, assuming there's one available for this model ? Thanks
Posts: 8,205 Likes: 234
I haven't checked but my grandson has a Makita bent shaft line trimmer and he said a new head for that machine is $80, I think somebody is stitching somebody on these heads
I bought a new original head for my Pope 33cc trimmer, nylon and only $26... Check the tip shop... for compatible unit. speedy
I bought a new original head for my Pope 33cc trimmer, nylon and only $26... Check the tip shop... for compatible unit. speedy I can get an aftermarket head for around $20, not too sure about Genuine, I think I saw some for double that, can't find where I saw it. No tip shop near me either :(>> there is a 'junk yard' I haven't been to in a long while, but last time I went there, they were pretty expensive... might have a squiz anyways. Where can I find a list of cross-compatible brands that might share they same/similar heads ? Or will any head pretty much fit, as long as the bolt hole size matches ?
I have a pile of line trimmers here and I doubt any 2 are the same, I occasionally scratch around through them trying to mix and match but usually don't have much success
Topics12,743
Posts106,754
Members18,040
