0 members (), 454 guests, and 1,650 robots.
Masport Shitemaster 720 blade
#96348 17/02/19 06:38 PM
I Have the opportunity to acquire a rover rancher 28189/198 Model no 3784821 can someone confirm the deck size on one of these is 38 inch cut. It is currently fitted with a 16 hp vanguard (briggs and stratton) motor which needs replacement. will a briggs and stratton fit straight in or woul significant modifications be needed. the deck and the drive are in excellent order
coolrussy #96351 17/02/19 07:35 PM
Looks like it is a 16hp 38 inch cut auto drive. We have recently established that at least up to 18hp, could be higher, the Briggs bolt pattern remains the same
coolrussy #96353 17/02/19 10:00 PM
Thank you but I am seriously looking at a 15.5 hp briggs as the higher hp is out of my price range
coolrussy #96356 17/02/19 11:12 PM
The only thing might the wiring setup as that depends how each engine is setup. Just minor changes most times.
coolrussy #96363 18/02/19 06:21 AM
As I said the bolt pattern is the same
coolrussy #96373 18/02/19 11:23 AM
Are crankshaft lengths of the vanguard and the proposed intech
coolrussy #96374 18/02/19 11:34 AM
They all seem to be about the same length of 80mm What sort of money is the Intech. I thought it was the Intech motor that LRT was having problems with low use ones wearing the bores oval. Not sure I could be wrong.
coolrussy #96380 18/02/19 12:59 PM
Can pick up an intech 15.5 for less than 900 excluding freight. Also I have been told by my mower mechanic to be careful re wiring how compatible are the vanguard and intech wiring and what mods if any are required
coolrussy #96381 18/02/19 01:55 PM
Can pick up a 16hp Chonda for under $500
coolrussy #96426 19/02/19 12:20 PM
Maybe so but too many issues with wiring etc
coolrussy #96428 19/02/19 01:16 PM
Only need to connect the alternator wire to charge the battery and you need to connect the starter wire from the solonoid to the starter motor
Reddy, Nick Stefano, MeMyself&I, hughyy, Shehdhhe
18,064 Registered Users
Topics12,746
Posts106,765
Members18,064
