#92894 12/09/18 10:18 AM
I had a vertical pull Quantam motor that the pull start was broken so I figured I would just swap it over to a horizontal top pull, can't be that hard. I ended up spending hours messing around, modifying this, then that only to reach the conclusion that the flywheel being thinner on the top pull has the coil sitting a bit higher on the flywheel means the spark is not right. I got it to run a couple of times for a few seconds but that was about it. I will try lowering the coil but if that doesn't work I guess that is the end of it. All part of seeing just what you can achieve and keeps you on your toes and the grey matter turning over
NormK #92895 12/09/18 10:38 AM
Never a waste of time if you can use the experience down the track. You've at least done it now.
NormK #92899 12/09/18 05:46 PM
With this I hope nobody will be silly enough to try it again
NormK #92904 13/09/18 12:14 AM
G'day Norm and Mowerfreak.
Very well said Norm!
A lesson in learn by experience.
I hope this helps others, as it has helped me.
NormK #95924 03/02/19 01:58 PM
Just to update this I got back to it, ground down the coil mounting points by 10mm , got spark and it runs well . Big effort but a good learning experience
18,212 Registered Users
Posts106,871
Members18,213
