1 members (Bruce), 5,280 guests, and 1,646 robots.
#91551 28/05/18 08:28 PM
My mates Super 250 just won't start..... it's only 48 years old and done heaps of work..................
I put some fuel into the carb and it started......, did it a couple of times....
Been googling US forums and one said just keep priming and after 10 starts it might pull the fuel through...
Anyway I took the Tillotson HL63 carb off and want to clean it....
A kit cost $56......my father in law reckons the thing is not worth $56..... so I want to tread lightly and clean the carb, maybe it will work again with some carb cleaner and air.................................... try to keep the old gaskets...
He's going to give me a ride on mower that doesn't go either..........
fun goes on , when time permits
speedy #91558 29/05/18 09:14 AM
I'd get a kit - you couldn't get an equivalent saw for $56 .... Great saw - just check piston and bore before spending. $$$$
speedy #91665 07/06/18 08:37 PM
hi Dieselboy
I took the carb off and tried to lever the sections open with a blade and squirted in carb cleaner..... tried to take it apart without destroying gaskets..
Just to get it going. It kicked over, even used engine start spray.....
There's spark, and heaps of compression. It's a workout to pull it over a few times.......
I will check the points, as it has contact breaker points....
See if plug is wet......
speedy #91666 07/06/18 10:19 PM
Soak it in acetone overnight......Have you checked piston, rings and bore.....? Good luck - I'm a sucker for old chain saws
speedy #91671 07/06/18 11:26 PM
Parts are nearly impossible to get for these old saws if is the McCulloch as they have been out business a good number years now. If it has good compression and fires on a fuel mix prime then the carburetor is likely the root cause.
With this being 48yrs old I would not expect the gaskets will loosen without tearing. And getting a kit is best if available and you are willing to buy one as they are expensive now due they are becoming rare, plus you have to pay a premium because of the currency exchange rates.
speedy #91697 11/06/18 08:44 PM
I checked the air flywheel gap , set it to 17 , slight spark, points area dirty........
My ozito water blaster does the job at $ 87.
Just checking it all over...... is so dirty after 48 years....
speedy #91702 12/06/18 01:18 PM
Watch the points and capacitor completely dry - any moisture will rob you of spark
speedy #91751 15/06/18 08:36 PM
I have to reface points and set. and maybe check condenser....
But I guess to turn motor over you go on other side clutch area....
My mate is not in hurry and I have a lott \\ on ..... but it's relaxing just settling into a problem........
i sold his mums old rover for $50 so I owe him some time......................
speedy #91868 25/06/18 08:18 PM
Refaced the points gap 20 th inch, set gap flywheel 17 th inch .... I soldered a loose wire ends coil to points.....
now I have no spark........
I'll check a connection to coil.
It's electrical......................
Just got to check a solder job.
speedy.........
speedy #91870 26/06/18 01:19 PM
G'day speedy,
Here's an IPL download for the Super 250, which may be of some help; http://www.smallenginediscount.com/Super_250_May_70.pdf
If you're not getting a good spark at 0.017" flywheel air gap, try 0.010" - that seems to be a common spec for Macs of that vintage.
speedy #91923 01/07/18 07:28 AM
Thanks Gadge. I set the flywheel gap and it got a good clean and checkup. I must have a short , where the wires attach to points post. There's a fibre sheet.... I'll check
speedy #91960 04/07/18 06:49 AM
I have got spark. Just couldn't see it in the light........ Not a big spark. It didn't kick over even with starter fluid, then my arm wore out..........
Try again soon.
speedy #93439 10/10/18 05:49 PM
I put a kit in the tillitson carb, and a new fuel line. It didn't kick over, I want to check the reed valve.....
But how do you get to it? It's under where I took the carb out, removed 2 bolts, and the handle bolt...
there's the oiler rod...
speedy #93453 10/10/18 10:58 PM
G'day speedy,
Yep, that airbox does have to come right off, as the reed plate is sandwiched between it and the barrel.
By the look of that IPL I've linked above, there will be two external slotted screws that go through lugs at the front of the airbox. As well as the two internal hex bolts, and the handle screw. Look at Fig 4 as well as Fig 1 to get the idea.
speedy #93485 12/10/18 03:05 PM
I would have to take oil and fuel tanks off...... new gaskets etc. I shone a light through the inlet and could see the reed valves. They looked ok, seating and not bent. I put my thumb over intake and could feel them pulse when I pulled the starter, so I will take them as OK.
But a weak spark, found a washer on the flywheel magnet??? Anyway took the flywheel and will recheck points and wires. Someone suggested pinched wires.... maybe a new condensor..
Here's a tip I read maybe here about how to hold a flywheel to take the top nut off. Just thought I bring it up for ones who didn't know the easy way to hold a piston in place with telecom rope or light rope.
Nice rain in Bundy lately, missed the tennis ball size hail and the two tornados..............
speedy #93493 13/10/18 12:46 AM
I wish I had your patience. Working on this would drive me crazy, even though I love real chainsaws like this.
speedy #93619 19/10/18 07:46 AM
There is a weak spark, I want to try a new condensor.
Just wondering if a Victa one would do the job? Maybe I should just try it.
speedy #93622 19/10/18 08:49 AM
Well Speedy if you happen to have a Powertorque module why not try that, then you don't need the coil or the points, nothing to loose.
speedy #93643 19/10/18 08:25 PM
I seen where you say it had heaps of compression but did actually measured it?
Here I use 100 psi as a measure of minimum compression for a starting 2 cycle engine. Below that I seldom get one to start. It can be just stuck ring(s). I also had a couple Stihl 2 two cycles lately that had plenty of compression according to my gauge but losing it just the top of the compression stroke due upper cylinder damage.
speedy #93715 22/10/18 04:31 PM
I have a module from a 160 full crank, I think. Anyway I connected it up, you need to keep coil, but points and condenser went.
Not a big spark, but I could feel a bit of voltage in my fingers....
Maybe a better coil and module would do the trick.
Hi AVB I'll try to get a compression gauge and test.....
Bundy
speedy #93717 22/10/18 04:54 PM
Speedy, you said you had a weak spark with the points, is it any better with the module fitted? You need to be able to see the spark through the spark plug held against the head to get an idea if the spark is good enough
speedy #93736 23/10/18 06:56 AM
The spark is weaker with module, but still just see it with points.
I want a big blue spark like many B & S engines I have worked on. I have a few BS coils. Might try to put one on....
I'll measure the holes on the Mac coil.
speedy #93739 23/10/18 08:24 AM
Don't attempt it speedy it won't work, you can't get the timing correct, don't ask me how I know. It sounds like your coil is the problem and that will probably be the end of the chain saw. I have a Solo chain saw here with a dead coil, just haven't got around to taking it to the scrap and it is in good condition apart from the coil. I also has an Echo blower with a dead coil that I tried to fix for a friend, just on $100 for a coil so it to went too the scrap.
speedy #93744 23/10/18 12:28 PM
If you are using resistor plugs that spark will appear weaker. If using a resistor plug try a non resistor type.
Also the color will not always be bright blue. If you live near the sea coast it can even be orange due to sodium in the air. Here the sparks are usually white.
speedy #93793 25/10/18 08:26 PM
Thanks AVB, when I use a non resister plug, people around the neighbourhood have problems with their TVs ............
The guys down the road have an old motorbike and when I hear it start the TV goes haywire......
It did fire for a blast once..... that's why I keep going.
Is there a way to test the coil? My mate will but another coil as he wants to get this old thing setup as a log slab cutter. He will make a steel frame up and make slabs. They use them for fencing... and other things.
thanks
speedy #93794 26/10/18 03:30 AM
Speedy which coil do you have? Or would you rather have the 1963 service manual and the 1965 supplement?
speedy #93795 26/10/18 07:46 AM
It's a 1970 model saw, with a yellowcoil. I will get the number.
speedy #93796 26/10/18 09:06 AM
See if this helps then.
speedy #93962 07/11/18 11:56 AM
AVB, It has E67 stamped on coil,so it's top row.
Just bought a cheap multimeter, so now I will do some measurements.............. bit of a learning curve/hurdle.
speedy #94062 10/11/18 06:51 PM
OK AVB I did some testing and familiarising with multimeter.
Got reading of .02 on primary , should be .025 to .5, but then it was all over the shop... changing........
But the secondary was more stable at 5.89, should be 3.5 to 5.00
I will look around for another coil...... they are laying around sheds etc , just a matter of finding one.....
Moderated by  Bruce, Mr Davis
Brad73, Hksmonaro, Kellogs75, Gubba, fiercertonks
18,188 Registered Users
Posts106,827
Members18,188
