4 members (Buckets, John Howard, 2 invisible), 914 guests, and 1,242 robots.
My Hyundai Mower is surging.
by aLaw13 - 20/04/26 01:29 AM
Rover height adjust plate
by Bruce - 07/04/26 03:39 PM
YardKing 4 stroke spare parts
Page 2 of 7 1 2 3 4 5 6 7
Hi speedy, glad to hear it works well, problem is now that you have seen how well they work you would never go back to the original design
Yes, I will get my new pt going first then do the mod. I didn't put the kill switch in or the bolts... but the rest works well.
Thanks heaps for taking the time to complete this mod, photograph it and post it.
1: I will be applying it asap to my twin, which should sort one of it's problems once and for all.
2; Off to the "Green Shed" to see how many G4's I can score (attached to cheap mowers of course!)
On that, most municipalities have a Green Shed where folks donate unwanted/broken stuff.
Always plenty of mowers, some in surprisingly good order. Just got to be quick though because they are usually stored outside and the fuel cap is the first souvenir to be taken.
The next thing that you will find is the float needle, this horrible little part is responsible for the early demise of millions of Victas. The new float needles and primer caps solve this although I have had a couple of issues with them, price on them is an issue if you only want one or two. Do not waste your money buying the ebay ones with the plastic needle they will mess with your head
1 member likes this: Colrose
I have a couple of questions for you about your carby mod, if you could offer some answers that would be terrific. I have been thinking about doing this to a spare carb for some time, as I have a couple of machines I use regularly that I think are in overall pretty good shape (seals, viton tipped needle and seat, clear jet, good spark, good compression etc.) which I can never get to start first pull cold. They often start second pull, run perfectly and restart easily hot. I don�t run them out of fuel to stop them but use stabil in the mix. What is the starting procedure with the modded carby? Throttle to run, single prime then start etc? Or are they all different and once you find a procedure that works for that machine go with it? Can I do the cam mod and not do the idle control screw or kill wires portion of the mod? I know I could try this all myself but wondered if you had some ideas already.
John
Hi John, I usually start them on full throttle then back it off but I find they will usually start pretty much anywhere, but full throttle is the spot I prefer as it makes sure there is fuel going straight in. I usually give 2/3 primes. You don't have to do the idle screw, just means that if you pull the throttle back fully the motor will usually stop because it will idle down too low. The idle screw just means you can just crack open the poppet to allow it to idle. This can be played with by only fitting 2 washers under the cam, but this usually keeps the revs too high for my liking, when you are emptying the catcher etc. You can use the existing kill switch but I found them too problematic and this is probably because all the aftermarket kill switch rubbers are not fit for purpose, I was spending way too much time trying to get them to work only to have them play up. The most annoying thing with the whole setup is the lump on the cam that once the lifter goes over the top into the stop position it often becomes impossible for the throttle cable to fight the spring tension and get the lifter to rise back up over the hump. Cutting the hump off gets rid of this problem but then you need to put the washers under the cam to lift it up to the same height as to what was the top of the hump. If Victa had just kept the hump height all the way, none of this would be a problem and the kill switch setup would have probably worked fine. The big problem is the cable has to fight going back up over the hump, fighting the spring and break away from the kill switch rubber which can often jamb all at once.
Thanks Norm, love your work. I think I�ll give it a burl and see how I go, cheers.
I made the cuts on the cam today, easily done with a dremel. I have a couple of G4 idle adjust caps, might try one of those. Just need the washers under the cam and will twist it on and try
Hi jds303,
I should have done it that way instead of using my hacksaw. I still haven't completed one fully, as the machine I was going to try it on has other issues that need fixing first. I should get it done pretty soon.
What grinding head did you use. I have a couple of sets with assorted grinders, but never know which ones to use for a given task.
Senior Contributor
I've been trying to get my head around this fix for a while now and wondering how best to go about it. I know virtually nothing about Victa mowers. New territory for me! I am going to see if I can fix the old carby as it is before I start attempting any modifications. I have a bad habit of making mistakes that I can never "undo". smashpc
Hi Mowerfreak,
John
Hi Norm K,
17,929 Registered Users
Topics13,086
Posts107,369
Members17,930
PHP: 8.3.30 Page Time: 0.070s Queries: 58 (0.060s) Memory: 0.7368 MB (Peak: 0.8518 MB) Data Comp: Zlib Server Time: 2026-04-23 00:29:17 UTC
