2 members (Bruce, noileg), 2,023 guests, and 2,324 robots.
Hi Guys
i got some drama with my 12.5hp tecumseh..
basicly i stripped it down, honed bore as it was just glazed inside bore.
put new rings within specs, valves seem ok,carby kit put in, new filter,fuel and air.assembled and it ran fine, blew some on initial start up 10 minutes then all was running smooth as.
now i just cant start it, compression seems ok, goes around to one point and gets compression tight?
new ignition thingo lol
i have now dissasembled again and all is ok internally and i lapped valves this time round.. can anyone advise on lash settings? .004 is what books said but its 3 years young engine.. any ideas???
Toroman
Toroman,
1. Did you put the conrod back on properly as per workshop manual?
2. Did you line up the timing marks for the valve lifter cam?
3. Did you put the rings in correctly pic below?
Are you using a workshop manual for your spec's?
Piston ring guide
Hi Bruce
1) yes
2) yes crank/valve and balance shaft match marks
3) No,might have turned 1st one wrong, what happens then?
4) yes 740043
another thing is the float was not as specs say, 4.36 mm sloaping, i live and learn..i will put it together when i find some new conn rod bolts, old ones seen better days last thing i need is to throw a conn rod as bolts come undone.do you have any to buy?..Thanks heaps Bruce......toroman
yes in my mind i thought it said UP and OUT in book not UP and IN Facing, if that makes sense...Taa..Toroman
Hi Bruce, im going to get a new connrod/bolts kit so no need for bolts now..Cheers Toroman
danj, Jason92, sofini23, DavidMac, Outbacker
18,142 Registered Users
Members18,143
