1 members (JEH), 5,879 guests, and 322 robots.
Page 1 of 3 1 2 3
I just completed this conversion into a trolley/barrow. I was going to throw out the body anyway, due to rust starting to penetrate next to the left handle mount but decided to try making up a trolley out of stuff lying around the home. Despite appearances, it turned out very sturdy. I plan to do minor mods to front to make it a bit stronger, but it's ready to go.
Good one mowerfreak, I use same base to carry besser bricks etc, save my back.............
I was going to screw a couple of bits of wood on to make flatter base, ....... but I might find an engine...
Makes me cry seeing a good set of wheels being used like that, wheels are the most difficult component for me to find.
It's called get a proper wheel barrow, lawnmowers are lawnmowers wink
Gotta agree with Norm on that point.
Hi Norm K,
The front treads are quite scrubbed on the inside, they don't look as good in real life and the bearings have a bit of play. Yes they are passable and I have much more worn older ones that will do the job just as well so I can save these.
G'day BB,
but a wheelbarrow isn't a mower base converted using engenuity free of charge!
G'day Mowerfreak
I wish more folks would do this. Good job!
My folks tell the story of how Dad, with an expanding family,
extended the house. He cut the roof and used an old Qualcast pushie
to move the roof section along wooden rails. It worked!
I do draw a line, though, when some folks re-purpose lounge
chairs as ride-on seats. Just ask Norm about my HATE of this. mad
It is against the order of things - like pineapple on pizza.
G'day CyberJack,
looks like I have another supporter in this polarizing project of mine. Glad you think it's cool.
That's a great story of your father using it like a train and really demonstrated how sturdily they are built.
Regarding my contraption, I was going to replace the wheels with a set of the worst ones I could find, only to discover all but the front left one have a hairline crack along the shaft of the wheel which house the bearings. I have left them on and removed the only good one and replaced it with an old one with a radial crack in the tyre running from the white plastic rim ask the way out. It still works fine for this task. Now ready to use and abuse with impunity. yay
PS: I added pics of a wheel I was going to fit but painted first to disguise its wear, only to discover the faults with the existing wheels.
G'day Mowerfreak,
Many thanks for a great story.
Your story reminded me of this one - where an Eric Anderson/
Turner was re-purposed ...
https://www.outdoorking-forum.com.au/forum/ubbthreads.php?ubb=showflat&Number=72425
Do you have a name for your Vic-barrow?
Hey there CJ,
I refer to it as the wheel-barrel. One advantage of the Victa barrel is it's four wheels means less work having to support and balance it as you push it along.
I decided to just put back the original plastic front wheel, as I figured it won't be subject to the same punishment as mowing duty, and I can always remove it if I need to put it on a mower.
Plus, why have one odd wheel after the work I put into it?
G'day Mowerfreak
Yes, four wheels clearly is a good idea.
I don't even know why the barrow evolved with a single wheel,
but I guess it had a lot to do with building practices and use of planks
in the day.
Using lawnmowers has a proud heritage:-
https://www.outdoorking-forum.com.au/forum/u...mowers-the-odd-inventions.html#Post58306
You carry on a great tradition!
I might add, I appreciate both practical and artistic re-birthing ...
as seen in the two gallery images below.
Many thanks
p.s. the annoying thing in the second image - of the Pope flowerbed is the composition.
Almost perfect, but why wasn't the gnome moved forward, and be central in the lower
mower handle frame? This would have added another artistic layer!
Otherwise, look at the ordered geometry of the wheels (top left), to the jumble
of bits (top right).
I saw a good one today (not quite in the same way as your creation Mowerfreak) but ingenious none the less.
It was a old briggs powered lawn edger (like a little wonder lawn edger from the 70s) morphed with a stihl leaf blower. What the guy had done was made a mounting brace that he could place his stihl leaf blower on. Then there was a pipe, terminating with a right angle towards the edger blade. That meant when he edged (with the leaf blower on) it blew the cuttings onto the lawn that he would then mow over.
Probably not an original idea, and wouldn't safe him much time, and made a lot more noise, but I thought it was a good effort.
Was driving past, so I couldnt get a photo though frown
Regards
Tyler
G'day CyberJack, G'day Tyler, that sounds like more trouble than it's worth, albeit logical -on paper.
I presume the Stihl had a fixed throttle position, otherwise that would require some coordination to operate.
It's good to see what other repurposing has been done as a result of my post, just to learn new ideas.
Here is my Victa Corvette Hand Trolley. cool
Regards
1 member likes this: tortoise2
If I get a chance tomorrow I will get a pic of my Victa Victa trolley.
p.s. the annoying thing in the second image - of the Pope flowerbed - is the composition].
Jack I can't believe you snuck this in and nobody noticed, very clever.
G;day Norm, Max and all.
The interesting thing - for me - is the reproduction of ideas over time.
Max, mowerfreak, yourself and others carry on that tradition.
Adapt and overcome seem a part of the AUS psyche.
Thanks Norm! I am a keen observer of image composition.
I think maxwestern's creation could fetch more than the mower it came from. A Victa themed hand truck.
This is my Victa Victa trolley and yes MF the trolley is an alloy base and a bloke wanted to buy it a few days ago but I told him I needed my trolley. I don't think he was too happy that I wouldn't sell it to him. I think I need to build another trolley so I can stack some more bases because it makes it easier to move them around. If I could just get wheels I could put a lot of these bases back to work
Hey Normie, don't despair, there must be enough rotted out bases with decent wheels to eventually see them out.
You must be using bolts to make that balancing act.
MF, no bolts they just sit there happily waiting for a rebirth, I don't move it around much but I can if I need to. Problem is I think the base sitting on the bottom is rusted out and needs to go to the scrap, I guess it will have to wait till the next trip. Can't see me ever finding enough wheels, I do use other wheels from time to time but that means I have to cut the axles off and weld or bolt 1/2 inch ones on. Bit of a pain but helps solve a few of the problems.
I'm amazed they don't tip over. They must all find their posi and somehow jam against each other.
G'day all.
Norm, That's a nice composition there - the deck of mowers smile
There is something cannibalistic about it.
Is that one single party light top-right?
I wonder how Sigmund Freud would interpret this?
Hi Jack, I guess I hadn't looked at it as an art form but I can see the potential in it..... I think? Obviously the people at the gallery are looking at it in some depth. As for the deck of mowers, it is actually a deck of mowers sitting on a deck that is sitting on a deck, that is the concrete deck that we poured over where the swimming pool was because everybody thought it was a bad idea for me to fill it in with grass clippings. There is now 35 x 200 liter plastic drums under there that are full of water for the garden. And yes you are very observant, that is a party light that has been there for about 35 years for when we had pool parties many years ago
Hi All,
Hmmm ,I have had the Victa trolley like Norm from time to time .
I have yet to see a Victa snow plough or a Victa mower rake.
Boy would I love to get into that pile Max, gotta be some good wheels in there somewhere, looks like they were just grabbing the motors
Wow Maxwestern, a lot of repurposing to be had there apart from being an apartment complex for redbacks!
CyberJack, brilliant Photoshop, and very flattering.
NormK, I somehow knew you'd be salivating over all those wheels in the wall of mower decks laugh
MF, do you wheely think I have an obsession with wheels
You're obviously a wheel nut Norm!!
Yes that's some nice artwork Jack with the Photoshop image,here are some more mower art pics, not my work though.
Some good wheels there Norm but only 5 bases in that lot are not rusted out.
I think someone could get a lot of repurposing out of the Victa wall Mowerfreak ,I guess it depends on their imagination.
Yes Max, that rust is the Victa killer (apart from the wheels, yes MF I know). Everyone I get back to work I clean on the inside all up around the left inside and then paint it with fish oil. Hopefully that will save them for a few more years. The other issue with the bases is the wear that happens where the front axle goes through the body, not a huge problem because I just weld that area up, but still an annoyance. I guess Victa had to build something into them to make them fail or people would have been able to leave them in their will to their children and grand children. As for the photoshopping the reflections on the floor make it so realistic, means you can't believe anything you see these days
Page 1 of 3 1 2 3
18,225 Registered Users
Topics12,776
Posts106,878
Members18,226
