2 members (GFazz, looktall), 8,731 guests, and 257 robots.
#91397 10/05/18 07:49 PM
I have ended up with a 158cc Briggs that has done very little work because it was mounted on a pressure washer. It has a 35mm long shaft that is no good for a mower so I am at a loss as to what I could use it on. Pity because it is a good motor
NormK #91399 10/05/18 11:44 PM
not a problem, put it on a Victa base, facing east/west (like the early Briggs on Victa's) without the spacer ring. Depending on which boss you use, you may have to put it on some 5mm spacers to bring the blade up a little.
Alternately, if you don't want it i'd gladly take it off your hands.
Cheers, Ted
NormK #91402 11/05/18 10:00 PM
Thanks bigted, I did look at putting it on a Victa base but tried it in the normal later type position but as you would know without the spacer ring the fuel tank will not fit. I hadn't considered turning the motor sideways and it would look a little odd seeing this motor has the curved plastic cowl top. I will see if it will fit on one of the early Rover Rapid side throws I have here. They seem fairly shallow and not having the catcher chute the tank should not foul the tank
NormK #91405 11/05/18 10:55 PM
If it runs, you MUST find a use. It's the law!
NormK #91406 11/05/18 11:01 PM
Runs as new, I doubt the oil has been changed, clean as like new.
NormK #91407 11/05/18 11:07 PM
Let us know how you go. Sounds too good to scrap if it has so much of it's design life to go.
NormK #91414 13/05/18 10:34 AM
Senior Contributor
You can buy shaft extenders on places like e-bad. But I'm not sure of their specs or if they would even be suitable for use on mowers??? They certainly have industry standard applications.
NormK #91416 13/05/18 10:55 AM
The problem with any shaft extender is how you could bolt the blade carrier on
NormK #91417 13/05/18 11:06 AM
Senior Contributor
Yes Norm, I've wondered about that myself. I had the same problem some years ago and looked at shaft extenders. Ended up shaking my head in frustration. It all seemed too hard and probably was. I recall many years ago a local farmer extended an engine shaft by welding an extra piece on to it. But he was a very competent welder and everybody for miles around took things to him to get welded. So I guess this is possible, but of course requires that the whole engine be pulled down to remove the crankshaft, otherwise the heat will melt the oil seal and potentially melt or warp the nearby casing. Reducing a shaft is problem enough, unless installing a spacer as a simple fix, but extending a mower shaft is not an easy task and seldom achievable.
NormK #91418 13/05/18 11:23 AM
I have done it before but the hours involved make it not worth the effort. Cutting the keyway with a file is not fun. I have a mate who can cut the keyway but for a mower it just isn't a worthwhile cost effort
NormK #91429 13/05/18 08:35 PM
Senior Contributor
I cut a keyway with a file one time. Took me hours. Very slow process and next day my arm was aching something terrible.
NormK #91433 13/05/18 11:23 PM
Norm, just put it sideways on a victa and remove the plastic cowl. It will look entirely normal that way.
NormK #91435 14/05/18 09:16 AM
Thanks bigted, my only issue with that is it puts the pull start across the mower not along the length of it.
NormK #91436 14/05/18 05:29 PM
Trust me, you don't want that. I bought a Victa VC160 that was set up like that and it kept tipping toward me. I don't know how the previous owner thought that was a good idea.
NormK #91437 15/05/18 12:27 AM
Hi Norm and MF, I've done a few, just drill out the 3 rivets and rotate the starter 90 degrees, then rivet it back in, make sure you use 3/16" or 5mm rivets.
18,215 Registered Users
Posts106,871
Members18,215
