1 members (looktall), 6,733 guests, and 1,702 robots.
#9039 03/08/08 06:40 AM
Hi all, picked up a Bolens mower here with a 16hp Briggs twin opposing 108deg. Was running a bit rough so i thought i'd tune it up a bit. Got a new air filter and started playing with the carb. Found out there is only an idle speed screw and an idle mix screw. So i got it idling very nice but after that it starves for fuel when you give it some throttle. I pulled it apart and blew through each hole with the compressor but no difference, once it warms up quite a bit it seems to go better (better response etc) but i would like to know what to do to get it working properly from the time i start it. My next thouoght was to buy some carb cleaner and soak everything in it? or spray it in each hole and leave it for a while? not sure how it works, never used it. Maybe there is something else i can do. Motor infi is:
Model
402707
Type
0160 01
Code
85051512
Any help appreciated...
Gary.
smythie #9042 03/08/08 02:17 PM
smythie,
Did you check the throttle shaft bushes and for wear on the throttle shaft as this could cause air leaks throwing out the mixture. As it has a fixed high speed jet make sure that you have it screwed down correctly.
Also did you replace the pump diaphragms?
We do have a workshop manual that can be uploaded to the parts list and manuals area but it is over 5MB. If you wanted just the carby info uploaded it would be a lot smaller size. cheers2
Bruce #9044 03/08/08 05:18 PM
Ive been looking for the manual Bruce, i have no prob with 5 meg, your call...any info appreciated. I havn't had a good go at the carbie yet, just a quick pull apart and basic clean and reinstall.
Gary
18,197 Registered Users
Posts106,846
Members18,197
