0 members (), 430 guests, and 1,668 robots.
Hi Everyone,
My newly acquired Supercut, possibly will be in need of an engine swap.
The Villiers 2stroke, doesnt seem to want to run.... I havent given up hope just yet, but i would like to arm myself with some options if the Villiers is to be retired.
Has any one had experience in retrofitting a later 4 stroke engine, EG briggs 3.5hp 550 Series?
Any tips/info would be great.
Aiden
Hello Aiden
This is the bigger Villiers Mk25C 2-stroke.
Bits are still available.
An engine swap would be the last thing to do - for the simple
reason that the engine mounts are unique to this engine.
You would need to modify the base mounts to accommodate a modern 4-stroke.
A 4-stroke will not bolt on; neither will any other 2-stroke in any simple way.
It would be a shame to lose that connection - between mower and original engine.
That is a personal view.
If you know engine theory, and the engine has compression and spark,
then the fuel mix must be fresh. It is possible that the engine is miss-timed.
There are videos on YouTube to time the 25C.
Hi Aiden,
You could do an engine swap but you can only use an engine that has a 5/8 PTO shaft coming out of the crankcase. The bigger Honda's and Chonda's have all got 3/4 inch (19mm) PTO shafts which is too big to suit the counter weighted sprocket.
Yeah the Villiers are a pretty hardy engine, not much to go wrong. I'd be checking the usuals first
New spark plug
Confirm coil is in good shape
New fuel
Carby is clean/ operating
Get back to us
With the original engine up and running it is a far more interesting machine with than one with a modern chonda motor fitted, it looses all its heritage then.
Hi guys,
Couldn't agree more with you Norm, thus why I originally suggested in a PM to Aiden that it should only require a fuel system service as it has both spark and compression and with it being a 2 stroke it will probably require a full chemical cleaning of residual 2 stroke oil that has congealed in the carburetor, thus blocking the supply of fuel.
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28 29 30
18,099 Registered Users
Topics12,750
Posts106,783
Members18,099
