3 members (AMP, Ausmow55, MowingManiac), 1,902 guests, and 690 robots.
Bushranger cylinder mower
Acrher Chainsaw Chain
by AVB - 21/01/26 09:00 AM
Model number - where is it?
by Koii - 12/01/26 12:06 PM
Sanli Redback Ret Spring
by NormK - 22/01/26 02:05 PM
by NormK - 21/01/26 09:55 PM
Rover Thoroughbred Model 85
Page 3 of 3 1 2 3
Hi Nicholas,
Looks like it was at either Scammel's or Lachies Auction House down at Welland.
Anyway it's a great survivor which you should use as it is, providing that the Kirby is running well. I love the good ones that are still all original and not molested.
If you require any help with it, I'm also here in Adelaide.
Hi Bonnar_Bloke,
the 20 inch was from Scammel's as you suggested. One of the lads at the pick up zone was telling me it came from Adelaide oval when I went to pick it up and hadn't been started in 20 years. Rolled it out onto the front lawn and first pull it started with fresh fuel. I plan to keep this one as it is but I might seal the reel up with a clear coat. Also, thanks for the offer to help out.
Nicholas
Hi Nicholas,
All you need now is the old Score Board and you'll have everything that's old left over from the venue, as everything is ultra modern there.
It deserves to be kept as a survivor as it's good enough to use as is.
Hi everyone, I got the mower primed and painted with the free time I had after New Years. It came out a bit light in my opinion however, it will have to do for now.
Last edited by Bonnar_Bloke; 06/01/18 02:32 PM. Reason: Resized Images to show on post
Hi Nicholas,
Glad to see the progress is continuing nicely.
I note that the paint is South Australian "Protec" brand ? Did you use the standard off the shelf colour "Olive Green" or was it custom mixed using a sample from your mower which Protec will do ?
Glad to see you painted the reel and not powder coat it. Who did the reel grind ?
Lots of questions I know but that's the sort of information that new members look for, much like you did I guess. It's all about the journey AND the destination here on ODK.
BTW the green looks ok IMHO, also have you received the new sloper Briggs engine ?
Hello Nicholas and ModBB
Brilliant work there.
Many thanks for the update - as many folks learn from these projects.
p.s. I really like the last image in the gallery.
The shadow reflection of the frame looks like a blue print. Brilliant!
Hi CyberJack and Bonnar_Bloke,
thank you both for your kind words, as for the details though please read below:
PAINT:
The paint was sourced from Protec and was not mixed to match (colour - Olive Green). This was because the sample given did look under their lights like the original as I did compare it with a piece of the mower. To paint the mower I used a etch primer from Dulux as I sandblasted the entire mower back to bare metal. The hammertone paint was thinned out using enamel thinners and then applied using a spray gun. the reel on the other hand was sprayed using a Dulux pressure pack (spray can) over etch primer masking of the shaft on either end for the bearings. In addition, to further protect the reel, 3 gloss clear coats were sprayed over the paint. On the other hand for the front roller assembly and various other parts, a zinc spray was applied and protected using a clear coat.
Link for paint: http://www.ppglic.com.au/uploads/tds/311%20Protec%20Hammertone.pdf
Link for paint video by Protec:
Link for etch primer: http://www.bunnings.com.au/dulux-metalshield-4l-light-grey-etch-primer_p1400541
Link for thinners (enamel for the hammertone): http://www.supercheapauto.com.au/Product/SCA-Premium-Enamel-Thinner-4-Litre/379650
Link for reel paint: http://www.bunnings.com.au/dulux-me...ue-red-epoxy-enamel-spray-paint_p1400825
Link for rear roller paint: http://www.bunnings.com.au/rust-oleum-340g-ultra-cover-2x-gloss-spray-paint-winter-grey_p1580820
Link for the zinc spray: http://www.bunnings.com.au/dy-mark-400g-silver-zinc_p1580764
REEL GRINDING:
The reel and bed-knife were ground by "Steve Rose" at Australian Saws & Blade and Cylinder Blade Sharpening Service on Research Road Pooraka, SA. I also had Steve replace the bearings and the bed knife screws while he was at it. Furthermore, the holes for the bed-knife had a tap passed through for extra measure.
Link for Google Maps:
http://www.google.com.au/maps/place/Cylinder+Blade+Sharpening+Service/@-34.818488,138.6352653,17z/data=!4m8!1m2!2m1!1spooraka+reel+sharpening!3m4!1s0x6ab0b6821a256985:0x41547158b07f578c!8m2!3d-34.818488!4d138.637454
PARTS:
The 3.5 hp Briggs and Stratton engine was bought off of Ebay from PowerMower located in SA for around $250 at the time. (See
link for the shops website for engine). The Stickers were sourced from Ebay along with the red plugs, grass catcher supports, replacement keys (for the clutch shaft, reel sprocket, and engine sprocket) and all new corks (clutch and thrust pad).
Link for B&S 3.5 hp engine: http://powermowers.com.au/collections/engines-biggest-range-in-s-a/products/briggs-stratton-engine
Link for Stickers (Chain Cover): http://www.ebay.com.au/itm/Scott-Bonnar-Model-45-Vintage-Mower-Chain-Cover-Decal/263391908646?hash=item3d53619326:g:pmEAAOSwiLdWCmZG
Link for Stickers (Winged Decal & emblem): http://www.ebay.com.au/itm/Scott-Bonnar-Model-45-Vintage-Mower-Winged-Decal/253331987814?hash=item3afbc35d66:m:mef9qSqodJ-xt19ksa4_qqA
Link for Red plugs : http://www.ebay.com.au/itm/Scott-Bonnar-Plugs-1-sets-of-3-plugs/142641679392?hash=item21361b4c20:g:5J4AAOSwnHZYkbgQ
Link for Grass catcher supports: http://www.ebay.com.au/itm/Scott-Bonnar-45-Rover-45-grass-catcher-supports/142643648565?hash=item2136395835:g:MDcAAOxy4fVTDckQ
Link for Replacement keys: http://www.ebay.com.au/itm/Scott-bonnar-rover-45-engine-sprocket-key-reel-sprocket-key-clutch-shaft-key/132383016709?hash=item1ed2a48705:g:qWwAAOSwGvhT8GpL
Link for New corks: http://www.ebay.com.au/itm/Scott-Bonnar-45-engine-and-traction-drive-lining-combo/132413358173?hash=item1ed473805d:g:2qIAAOxy7nNTPSOa
Hope this helps anyone laugh
Cheers, Nicholas
Hi Nicholas,
Thank you very much for your very comprehensive "go to links" for a Model 45 Restoration.
I understand that you've gone to a lot of effort to compile all this information and its superb that it's all in one post, but sadly all of the eBay links will in a very short time become defunct as the listings will all end and are relisted time and time again. Anyway it will give many potential restorers a good idea as where to look for many of the most commonly used bits and pieces that are sourced to do the whole job as you've done.
One thing that is missing I've noticed in all the photos is the handle bar assembly, what is happening there ? painting or Electroplating ?
I'd love to see it re-plated but we all understand if the cost refers you back to painting it. There aren't many plating shops left in Adelaide so there's not much competition in pricing. Sadly there have been just too many EPA rules and regulations introduced which makes it no longer cost effective to Electroplate here in Australia unless you charge like a wounded bull, which is pretty much what they all do now.
I guess all you have to do is see what's happened down Mitchell Park / Melrose Park way with all the ground water contamination that's come from all the Plating Shops etc. that used to be down in that area that were just pumping their waste plating solutions out all over the ground which was common practice in many industries for too many years.
Now it all has to be contained and transported to a Chemical processing plant to nuetralise it which costs huge money. Every shortcut has its ramifications I guess and now we have to live with the consequences of that stupidity that was engaged in for too many years.
Anyway I'm going slightly off topic here, but I still love to see a nicely chromed set of handle bars which compliment all the other hard work that's been done on the main working part of the machine.
Well done so far and we're looking forward to the next batch of photos as this project nears its completion point.
BTW what's happening with that lovely 20 inch Ex Adelaide Oval Scotty you bought recently ?
Hi Bonnar_Bloke,
I've decided to leave the handle bars all original since they cleaned up really well with Coke and aluminum foil. As for the rest of the mower I hope the pictures attached answer all your questions. Also, I plan on making the 17 inch a groomer down the line and using the 20 inch machine as is.
Lastly, I would like to thank everyone here for all their help and support!
Cheers. Nicholas
All images have been resized and been now moved into the above post.
But I thought I would provide a before and after photo just to show all members the transformation from when Nicholas first posted this machine on this thread last year and how its been finished this year.
Great job mate, should help a lot of people including me (I have 4 to restore), in sourcing all the paint and bits and pieces etc.
A quick question Nick,
How much was the Hammertone Paint from Protec ?
Hi Bonnar_Bloke,
the hammertone paint was around 40-50 dollars at the time of purchase, but may have gone up or down by now.
Nicholas
G'day Nicholas24, Mod BB and Members
This is a great topic.
Nicholas, many thanks for the superb story and image gallery you have created! laugh
I think this will help many folk who visit this site.
I feel this shows the relevancy of the Model 45.
It is a unique machine in lawnmower history - being both a vintage machine
and a modern daily driver.
I guess this is the difference between fashion and style.
The 45 has both - a rare thing today.
Page 3 of 3 1 2 3
17,805 Registered Users
Topics13,058
Posts107,236
Members17,805
PHP: 8.3.28 Page Time: 0.073s Queries: 47 (0.065s) Memory: 0.7219 MB (Peak: 0.8303 MB) Data Comp: Zlib Server Time: 2026-01-23 00:49:51 UTC
