1 members (bigted),
8,136
2,016
Hello I am having a problem with my Villiars mark 10 (v carby) stationary engine, which is running a small concrete mixer. It will only run with the strangler closed. If I open the strangler, after warm up, the engine cuts out. Does anyone have any ideas?
Hello Millzy 555 I found the manual some months ago and set the carby as per instructions, so I think there has to be another reason for this problem, but thanks for your interest and advice.
Posts: 6,938 Likes: 322
Hello Chesh and Millzy The symptoms you describe suggest a carby overhaul is needed. Setting the carby is the first step in diagnosis. Next step - carby overhaul and re-set as per Millzy's advice.
All the basic checks should be carried out first - compression, spark, fuel ... The initial suspect - after the basics - lies with fuel.
Please tell us how you go. Many thanks to Millzy for the link.
------------------ Jack
Hello Millzy and Jack, I've cleaned the fuel tank, filled up with fresh unleaded fuel? { hope this could not be the cause.} the compression is 100pc, and has a good strong spark, it seems the only thing left is to pull the engine out, put it on the bench, and start work on that Carburetter. I will keep you posted. Thanks.
Posts: 988 Likes: 7
Hello all, I would go through the carby and give it a good clean, gaskets are available from John at rusticspares.com.au if the engine was on a mixer it is probably set for running that load and will need a bit of attention for running light. Also give the air filter a good clean out as the gauze is usually blocked up.
Must be running very lean
Hello Paul You make a good point, will do! Thanks.
Hi Millzy, I removed the air filter, sprayed Nutcracker into the port, replaced the filter, problem solved, the Engine is running great. Thanks for your interest and advice.
Hi Paul, I removed filter, sprayed Nutcracker into the port, replaced the filter, and the Engine is running great, Strangler open. Thanks for your interest and support.
Posts106,871
Members18,216
