1 members (Brad_C),
5,580
1,642
Posts: 407 Likes: 2
I'm thinking of making up a portable engine driven battery charger and thought a Victa engine would suit that sort of application but would replacing the cutter base plate with a V belt pulley provide enough flywheel inertia to enable it to start & run without any alternator load?
The alternative would be to use a 'proper' 1990's Briggs & Stratton Quantum or a horizontal shaft engine, but the Victa is very light compared to the other 4 strokes, which makes it a lot easier to cart around.
Posts: 8,215 Likes: 235
Hi LRT, no problems using a Victa, just would have to use the early full cranks so that you can turn the motor on its side and then using say a G3 carb rotate it so the carby stands vertically, don't think you could do it with a plastic carb because rotating the carb would require a manifold modification. As for flywheel weight you could use a heavy pulley for the belt or fit a heavy disc to the pulley. The alternative is to retain the blade carrier, minus the blades and make a belt cover to cover it and the belt
Posts: 2,727 Likes: 220
I tried this experiment years ago using a J A P 4 stroke and a 35 amp alternator ,It was a wast of time the motor did not have enough power to run the alternator over the idle speed.Now old alternators are 85 amp and up and yes you will need a flywheel or a heavy cast iron pulley.Easier just buying a second hand generator for $40.
Posts: 4,675 Likes: 165
The Victa roller mowers (Victa Imperial was the name I think) of the 1970s had a 125 with modified G3 carbutettor, mounted with shaft horizontal. I think it was called a Victa power unit with red cowl instead of black and VC 160 style starter. Were these ever used in other applications?
When I look up the specs,a little bit of conflicting information.
An alternator typically takes about 1 HP (horse power) for every 25 amps of power generated. So, a 100 amp alternator will require about 4 HP at full output. Most alternators do not operate at full output for very long.
The alternator can take up as much as 35hp.
Looks like 5 HP powering a 45 amp -60 amp alternator.
Another site had this information. I simulated a test with a Summit one-wire, 100 ampere alternator and tested it at several RPMS. I loaded the alternator down with what I thought a fair representation of typical application of 65 DC amperes output at 13.65VDC. At 4500RPMs the alternator averaged over the 4 tests a measily 1.28 hp loss. It was really consistent with the high being 1.29 and the low 1.26 over the testing pulls.
Posts: 407 Likes: 2
We only run a small battery bank to run a few lights at night as we are not on mains power. (The SEC want $70,000 just to connect.) We use a 1963 and 1982 Lister diesel generators for the bigger electricity loads and running a 5kVa generator just to charge three deep cycle batteries isn't very efficient compared to an alternator or forklift battery charger. I found this article which seems to have a lot of info: https://www.homepower.com/sites/default/files/uploads/webextras/mark8.pdfAs long as the alternator can cool properly, the motor could be mounted vertically in a frame as on a lawn mower.
Posts: 407 Likes: 2
I've got a Honda E300 that just did the crank bearing but it only puts out 8 amps or so. It would take a week running 24 hours a day to charge the batteries unfortunately.
Posts: 407 Likes: 2
I do have one of these from a DC3, but it runs at 14,000 revs so would need some gearing up and a much bigger motor to run! https://www.ebay.com.au/itm/321825898759
I was at a bloke place today and he had a number of old stationary engines that just plonk along and with their big flywheels run on the smell of an oily rag. One he started up and ran today was originally used on a generator. That aside, apart from the $70,000 for a fraction of that cost you can set up and go completely off the grid, so why would anybody go down the path of spending all that money so the power companies can go and rip you blind with their never ending price rises. You don't know how well off your are without having those mongrels getting in your back pocket
LRT I'm a little confused the thread started out that you were wanting a small portable genset, I assumed you wanted to use to charge up a battery on a machine you might be working on to now wanting to run the lighting in the house etc. Has to be a way somehow, how do your neighbours do it?
Posts: 407 Likes: 2
Yes the Lister diesels plod along at 1,500 rpm and last an awful lot longer than the modern diesels of half the cubic capacity as they are under stressed.
I've got my grandfathers c1910 Lister petrol J1 to restore at some stage and it is rated at 2HP @850 rpm.
Yes I'm wanting a portable 12 Volt DC battery charger (Not a 240 Volt AC generator. The Listers run the power for the washing machine and the wool press. The battery inverter runs the lights at night to save fuel.)
I need to make up something to charge the batteries as we can't afford to put on solar at this stage. (We are not eligible for the solar rebates as we are not on the grid) The neighbours near here are all big NZ owned dairy farms but there's at least 3-5 km from our place to a power pole.
Isn't it great in this day and age that places in Victoria (it is a well populated state and not very big) still has pockets that are not serviced by the power grid, but I guess the people of Garvoc don't rate too much on the grubberment radar
My suggestion on the use of a cheap generator is good for running a few different power tools but not a good option for charging batteries to run a house off.It helps to have all the facts now.
That is a good document explaining the facts,a 35 amp alternator can be driven by a 3hp engine. A 100 amp alternator needs at least a 5 hp engine.For alternators between 100 and 200 amps the use of a 8 - 12 hp engine is recommended.
These figures I would say refer to a motor in peak running condition so if you use a old second hand engine that is well worn you may need the use of a bigger worn engine to get the horse power requirements.
Posts: 407 Likes: 2
Sorry I probably wasn't as clear as I should have been!
If I used a Victa, I'd definitely use one with a set of new rings but if I went the 4 stroke route I'd probably just buy a Chonda.
What horsepower does a Victa full crank 160cc theoretically produce?
Posts: 407 Likes: 2
Our battery bank is 550 amp hours so divided by 20 gives a C20 rate of 27.5 amps.
That means I only need a 3hp motor.
The HP specification was never included in the Victa 160 cc motor Manuals,I have read that go kart enthusiasts say the Victa 125cc two stroke Lawn mower was designed to cut grass at 3000rpm and gives 3hp. The old 125cc Victa mower ads say 3.6 HP.
The 160 cc Victa two stroke will be over the 3 HP mark that is required for the 35 amp alternator.
And I have plenty of full cranks here if you need any to play LRT, only problem is that drive to Garvoc
Posts: 129 Likes: 2
maybe you could build a wind generator, I think people use washing machine motors ,plenty diy plans on internet. lots of wind in NZ too. might be better than 2 stroke
Posts: 407 Likes: 2
Thanks maxwestern, it looks like the 160cc will suit perfectly.
Yes Norm, they are like hens teeth around here and yes, it's a rather long 300km drive from here to the other side of Melbourne!
Freebird, we do have a small wind turbine but the problem is we have long periods in the winter without any wind and not enough sunlight for solar.
Fisher & Paykel washing machine motors are considered to be the best for wind turbine applications.
If you run the Lister even semi regularly, why don't you just throw a separate 100Amp alternator on it to charge your battery bank? It would hardly notice the additional load and would probably use less fuel running for an hour than a Victa 2 stroke running for several hours even if you started it up just to do the charging anyway.
Posts: 407 Likes: 2
Good idea. The only problem is it would need a pulley fitted between the engine and the alternator as the crank isn't exposed. Lister TR1Maybe an electric motor driving an alternator? You are right about the fuel use. When we are shearing on a 45�C day under 75% load, the Lister still burns (and leaks!) about 1.5L per hour. We've bought a Lister TR3 to replace it as the TR1 has hardly any compression and has a spring to keep the dipstick in! Once we set up the TR3 I'll pull it down and rebuild it. Maybe ODK should set up a forum page for the bigger 'small' engines?
We seem to keep moving away from the initial request for a portable 12 volt charging unit to I assume charge up batteries in machinery around the place not to do with the power supply to the house?
Posts: 407 Likes: 2
No the primary use will be to charge the 12 volt batteries that the 12 to 240 volt inverter runs on and also have the benefit of being able to cart it around to charge vehicle batteries etc. Here is what I'm wanting to achieve, albeit direct drive: http://www.christieengineering.com.au/Brochures/GX10080ND.pdf
Ok well I have an 80 amp unused Bosh alternator sitting here, been on the shelf for probably 20 years and never found a use for it, just need to attach a motor to it somehow
Posts: 407 Likes: 2
Thanks Norm. I'd be happy to buy it off you and also buy a Victa motor to use with it.
However, at this stage I don't know when I'll be coming your way so it may be a few months before I can.
You are welcome to the alternator, I will never use it. I was thinking seeing it has a double pulley, just mount it on a frame similar to the one you posted and just put a horizontal shaft Chonda on it, they are so cheap
Posts: 407 Likes: 2
Thanks Norm. Yes a Chonda would be easier to set up and mount in a frame.
Topics12,760
Posts106,815
Members18,160
