1 members (bigted), 8,136 guests, and 2,016 robots.
This is my first time on a forum ( a forum virgin, I feel young again )
I have a couple of greenfield's, I am not sure how to get the clutch assembly out to replace cork on tractor 11 ( I think )
I also have an "anniversary" 12 which I can't get enough tension on cutting belt as soon as I hit long grass the blades stop spinning the belt on it now is "pix spa 850" it seems really loose when disengaged and if it put extra pressure on engage handle it works better.
I can fix most things but sometimes I need guidance.
Moocha
Hi Moocha
Welcome to these forums.
Some images would help confirm the 'tractor 11'
Information on uploading images HERE.
prd Offline
MOD & GREENFIELD TECHNICIAN
G'day Moocha,
I'm sure there are historical threads that deal with clutch replacement but I'm struggling to find them with the search function. I'll keep trying.
It's a long time since I took a transmission assembly out of a tractor and will need to go and refresh my memory in the shed tomorrow but from memory the only real 'issue' is removing other stuff to allow the assembly to be removed from underneath (lowered out of the machine). Like I said it's been a while but the clutch fork and it's mechanism needs to be removed and the entire cutter clutch pulley frame. Both are removed with a few bolts and then the bolts that hold the flangette's that hold the transmission shaft are removed and at least one of the bearings needs to be slid along the shaft (grub screw secured bearing retainer needs to be loosened) to allow the assembly to be 'wriggled' free and down. Rust on the shaft may make sliding the bearing and retainer a bit of struggle. Penetrating oil and fine emery paper is the go here.
Of course all that is from memory. I'll have look in the morning.
Can't help with the anniversary machine as I have no experience with them......but someone here will know smile
G'day all,
This thread details Greenfield clutch removal and relining very well, with plenty of good pics; https://www.outdoorking-forum.com.au/forum/ubbthreads.php/ubb/showflat/Number/61593/
It actually shows the 21 Anniversary 11hp model, but there are only minor detail differences from the earlier Tractor series.
18,215 Registered Users
Posts106,871
Members18,216
