1,264
260
So I have decided not to do a traditional restoration and go with a more custom approach will still go with the traditional green for the base and handles but will have polished brass nuts chrome where I can probably some updated wheels because I don't want to trade my kidney for a ridgy didgy set and what ever else I can think of along the way.
Victa Utility 509 in line for resto. Scott bonnar model 33 already in pieces. Atco reel mower unknown model is 4 stroke
![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2017/02/full-11099-32854-imag0308.jpg) It all starts here a fairly original model 4 wheels are bin worthy cracked and generally worn beyond repair haven't tried to start has good compression though and good spark
Got the old girl running today though as soon as the fuel tap was turned on fuel came flowing out of the primer are there rebuild kits available for these carbies?
![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2017/02/full-11099-32923-imag0333.jpg) Got bored so rolled the mowers out for a few happy snaps
Posts: 1,842 Likes: 14
Got the old girl running today though as soon as the fuel tap was turned on fuel came flowing out of the primer are there rebuild kits available for these carbies? Not as such. NOS needle/seat sets do come up on Fleabay, and they are the main wear part for these old 3F/3L carbies. Apart from that, the only parts which generally need replacing are the 4 fibre washers. Repair guide download: https://www.outdoorking-forum.com.au/pages/Victa/Carby%20Information/G3%20Carby/G3%20carby.pdfFloats do sometimes spring leaks and sink over time, but are usually repairable with soft solder after you get the fuel out.
Cheers, Gadge
Thanks gadge that link was very useful saved it for later reference . Any idea where I could source the fiber washers ? I've mainly only played with g4's before
Posts: 585 Likes: 8
fibre washers.......keep a watchful eye on fleabay.as gadge says ,they too do come up quit often.
Posts: 8,176 Likes: 232
If you type in victa 18 to ebay you get mostly early Victa stuff
The main fibre washer that has to be replaced, is the one that goes under the carby bowl retaining screw. It often doesn't survive being disturbed, when the bowl is pulled off. The others are also usually fine unless dismantled.
Fibre washer assortments are available in places like Bunnings plumbing section [~$4.50 for a 30 pk], and there should be something suitable as is, or usable with a bit of file work on the ID, in those.
Just a tip: to help the new washer survive a bit better, smear both sides with grease/vaseline before installing it.
Cheers, Gadge
Thanks guys for all the tips and advice fairly new to victas so learning as I go. Will more modern wheels fit or will I need something from that era ?
Keep the wheels you have, they are probably the most sought after parts. As far as I know, Victa has retained the same wheel spindle from the early days, length and diameter. I haven't actually checked but I'm guessing that is the case. If wrong happy to be told
Have only one good wheel out of 4 and this mower will be used so not real keen on the price of correct wheels
Have only one good wheel out of 4 and this mower will be used so not real keen on the price of correct wheels Have patience, grasshopper. GA Spares [the last Oz aftermarket supplier of these wheels] discontinued them a couple of years ago now, but I'm sure that a Chinese manufacturer will wake up to this market niche. Best to avoid the 'first on market' Chinese versions when they appear, but with time I'm sure they'll get some decent product on the FleaBay market. It's a bit like waiting for Rare Spares to get around to commissioning repro parts, that are NLA from Ford Aust ...
Cheers, Gadge
Well one can always dream in the mean time . Looking at making some cast alloy ones but keep getting stuck on where to source the actual rubber tyres next option make something else fit.
If you just want functional wheels, some others do fit. Quite a few other brands use 1/2" axles, [Honda, SupaSwift, Rover...]
Victa is a bit unique, in that they went to 9/16" diameter axles after the Model 5's, and stuck with that thereafter.
Cheers, Gadge
Thanks there always seems to be one manufacturer who goes against the grain and does there own thing .
You can often find plenty of Rover mowers with non worn out wheels on them because the Briggs has given up the ghost, cut the spindles off and weld them onto your Victa. A question to ask yourself, how many of these over 60 year old neglected Victas are pulled out of the back of a shed, bit of a carby clean and they fire straight up and capable of being put straight back to work. You don't see too many 4 strokes capable of that
I've it's very true though very simple to work on and very little to go wrong with them . That's why the search for some alternative wheels so it can keep doing what it does best, taming the lawn and killing mosquitoes.
You can often find plenty of Rover mowers with non worn out wheels on them because the Briggs has given up the ghost, cut the spindles off and weld them onto your Victa. A question to ask yourself, how many of these over 60 year old neglected Victas are pulled out of the back of a shed, bit of a carby clean and they fire straight up and capable of being put straight back to work. You don't see too many 4 strokes capable of that For sure. The old 125's are really hard to kill - it usually takes a real gutful of water or dirt to do it. Norm, the older Victa 18's up to ~1960 ran 1/2" diameter stub axles. It was only after that, that they went to the 9/16" size. A few years back now, I wanted to use some used Victa wheels I had on hand, for an oxy bottle trolley I was building. So the solution for axles was a couple of 9/16" high tensile bolts, and welding of 2 nuts onto each side of the frame to screw them into... I also built a trolley for a 60L oil drum based on a Victa axle and wheels.
Cheers, Gadge
Posts: 135 Likes: 5
There are plenty of Utility wheels around if you can make and weld 9/16" axles to your mower. I have one with these wheels which gets used and these wheels are solid and make the mower very easy t ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2017/02/full-3886-33002-victa_model_4_pittwater_mowers_unrestored4_3_2012_002_medium.jpg) o push.
Topics13,070
Posts107,301
Members17,870
