2 members (MowingManiac, Dandare), 2,710 guests, and 215 robots.
Victa Super 24/600
by Doug - 07/03/26 07:07 PM
Eaton Model 6/7
Early Morrison rotary mower
Victa Super 24/600
Eaton Model 6/7
by Bruce - 02/03/26 09:37 PM
by NormK - 22/02/26 02:31 PM
by Bruce - 20/02/26 12:02 AM
#821 03/09/00 05:13 PM
We have two stihl chainsws 009 &044 at the moment they will only start if you add fuel to the carby and then will not continue to run.
We have checked main and idle jets and the diaphrames seem intact ,spark is okay.
Could compression be the problem
could be compression. I dout it, I would check the fuel filters first. You can pull the fuel line off at the carb. fuel should pour out, with a little shake, of the saw.
If the compression was no good, you stoll could not start it easy, if at all.
The fuel screen in the inlet side of the
carb is the most common cause in my experience, take off the side with the one
screw in it, and see if the fine mesh is
clogged or partially so, only way to cure is
to replace the screen.
Bill Greer
Moderated by  Bruce, Mr Davis
17,872 Registered Users
Topics13,071
Posts107,310
Members17,873
PHP: 8.3.30 Page Time: 0.160s Queries: 20 (0.143s) Memory: 0.6236 MB (Peak: 0.6443 MB) Data Comp: Zlib Server Time: 2026-03-11 06:55:20 UTC
