4 members (mreddie, MowingManiac, Bruce, Dandare), 6,062 guests, and 1,870 robots.
IanOZ #80950 07/01/17 07:10 PM
Senior Contributor
Thanks for the welcome Paul, and another big thank you for answering my questions. I knew that "honeycomb" paintwork would have to have a technical name. I am in two minds about getting my chassis repainted. I can ask a local spray painter if he can replicate it. Or maybe I should leave it the way it is. The paintwork really isn't that bad for its age.
I'll take a photo of the engine when I get time. Mine looks like the one 4 pictures back, with the recoil starter and the letters EC-BIG (or is it EG-BIC?) on the block.
Thanks for the info on the spark plug. My dad had just been using a small Rover plug, which is only half the length. The problem was the end of the plug hole had built up a big lump of carbon which had welded itself to the metal. I had to very carefully re-thread it.
I will check out the Facebook page.
I do have another question. I wonder why the early model had no hole in the front inspection plate, but on the later models they added a hole. I've wondered what the purpose of this hole is, other than provide a good place for hornets to fill with mud. grin
Ian
IanOZ #80961 08/01/17 03:48 AM
Hi Ian,
No worries, the hole in the front is the crankcase breather. If you over fill the oil the engine will spray the excess oil out here, dual purpose :-)
IanOZ #81150 11/01/17 10:54 PM
Senior Contributor
Oh dear, I goofed badly on this one. After cleaning off the oil and gunk from the carriage, I discovered my mower is actually a KXD2 not a KXD4. I'm not sure why, but I had always thought it was a 4.
So I guess this means the correct crank for it is the wind up one?
Centre of bolt hole to centre of bolt hole is exactly 4" to mount a winder.
I will also need a new starter cap as the teeth are worn smooth. I am not sure if the one on mine is original or from a different mower. It has the letters "GED 139-2" and "HESS" stamped on the inside of the cap. It measures 3" 1/2 inch outside diameter, and 2" 3/4 inch inside diameter, and half inch centre hole.
I am also chasing a discharge chute, but I am sure an original will be near impossible to find. If anyone owns one, I would be very grateful for all of the measurements. Then I can try to make one that looks as close to an original as possible.
18,160 Registered Users
Topics12,761
Posts106,816
Members18,161
