1 members (Muddytrail),
9,891
2,397
Hi guys
Have a 2nd hand mower been using for a month or two. Starts and runs well but has no real throttle control. Checked the air filter and going to replace that and while it was off checked and the throttle linkage seems a bit off, one of the springs is badly stretched and bent.
Basically it will start fine but has no real throttle control between start and stop, which also works. Just always running at pretty high throttle.
Have no other complaints at this stage, is this worth fixing while getting other parts ?
BTW - Is the engine code under the covers ? Got this on a sticker on the engine tbs158u1g1, seems to be a Classic or Sprint late 90s. I believe air filter for it is 698369 if that helps ?
Victa obsessed
If it is a Chinese one, than throw it out. The way to identify this is to look at the back of the engine and see if it has fins cast into the engine block. If it doesn't, it is an American one and worth saving. Btw, u should be able to go to the tip and probably find a stuffed Chinese version of ur engine and that should probably have a decent governor spring. Don't bother stuffing around with mower shops and places like Bunnings as they will try 2 get u to buy a new mower. Ps my user name is actually totallyrandomVicta but the username thingy cut my username short.
Posts: 4,675 Likes: 165
I heard that American mowers typically have no throttle control. Just low and high setting on the side of the engine itself. Australians are the ones that insist on setting the revs on their machines. Sure it's nice to have that indulgence as the factory intended, but if it works fine otherwise...
Posts: 310 Likes: 1
Any Pics? will help to see it.
Regards, Paul
Such is life....... Nothing better than a "GreenField" just mowed..
If it is a Chinese one, than throw it out. The way to identify this is to look at the back of the engine and see if it has fins cast into the engine block. If it doesn't, it is an American one and worth saving I believe it's a US one ? I heard that American mowers typically have no throttle control. Just low and high setting on the side of the engine itself. Australians are the ones that insist on setting the revs on their machines. Sure it's nice to have that indulgence as the factory intended, but if it works fine otherwise... True. If it ain't broke and all that. More just need a few little bits and pieces so was doing a small list and considering whether or not to 'fix' this. Any Pics? will help to see it. Sure. ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2016/11/full-10824-31266-2016_11_23_22.01.11.jpg) ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2016/11/full-10824-31267-2016_11_23_21.59.28.jpg) There she is. Engine is 10A902-2135 E1-98060455
Posts: 962 Likes: 20
Yep, it's a 10 cubic inch 158cc Briggs and Stratton Quattro 40. Firstly, remove the cowl and clean all the grass etc under there, sometimes it impedes the governor function. After you've done that start her up and adjust the governor setting by bending the tabs, where the springs are anchored to, in or out to increase/decrease engine speed. The large spring controls high speed RPM while the small spring generally controls the idle speed. Don't worry too much about the mangled larger spring, you can cut those coils off and and bend out a new coil to anchor to the bendable tab. Let us know how you go. Cheers, Ted
Posts: 8,215 Likes: 235
Good little motor,and as bigted says , bit fidley to get the springs to work properly but it will work
Victa obsessed
If you could post some pics of the back of the engine, that would determine the origin of the engine. In the mean time, i would suggest haunting the local tip until you find a briggs and stratton sprint 375, classic 37 or quattro 40.
Totally, what is your dislike of the Chinese Briggs, they seem to work ok, it is the Chondas that are tip material when they start to give trouble
Ha, hopefully find an old school Briggs with side mounted, vertical pull starter and exposed spinning top.
Mowerfreak, I have a number of those, good old motor as long as you keep the oil up to them
Victa obsessed
Is that apart from the fact that they can be just as bad as chondas in some cases? But I agree with what you said about chondas
Yep, it's a 10 cubic inch 158cc Briggs and Stratton Quattro 40. Firstly, remove the cowl and clean all the grass etc under there, sometimes it impedes the governor function. After you've done that start her up and adjust the governor setting by bending the tabs, where the springs are anchored to, in or out to increase/decrease engine speed. The large spring controls high speed RPM while the small spring generally controls the idle speed. Don't worry too much about the mangled larger spring, you can cut those coils off and and bend out a new coil to anchor to the bendable tab. Let us know how you go. Cheers, Ted Are you Nostradamus ?  Yeah quite a bit of clippings underneath. Have had a play and can see how it works, without that big spring working there is very little effect of throttle lever movement on the plastic throttle thing whatsit on the carby. Other than that seems all good. Will get a few bits and pieces and sort this. Bloody new Echo has an issue with the starter cord and so am currently trying to sort that. Thanks guys. Wouldn't have thought Brigs would've been in China in the 90s ?
Posts: 1,548 Likes: 25
I heard that American mowers typically have no throttle control. Just low and high setting on the side of the engine itself. Australians are the ones that insist on setting the revs on their machines. Sure it's nice to have that indulgence as the factory intended, but if it works fine otherwise... It wasn't as much as the consumer choice here for the throttle-less control. It was force onto us by the manufactures as a cost saving method. And some the mowers here only have one governed speed and no high/low setting. Part of the blame also lays with the consumer too as they only want to buy the lowest priced mower. It just like not having oil drains any more on some engines. Now we either need to turn the engine on its side or use a siphon to change the oil. From my view as a tech and operator these versions are very inconvenient to me especially as you can't change the self propelled speeds without heavy drive belt wear.
Victa obsessed
No, Briggs started making in China in 2002 (I'm pretty sure) and basically all modern Briggs engines are Chinese. And for your info normk, when I say that Chinese Briggs are just as bad as some chondas, I mean this. An example of this is a 6 month old victa classic cut ohv that I spotted at the local mower reconditioners and asked what it was doing there, he turned it round and it had a 10cm by 5cm hole in the side of the CHINESE cast alloy block. This mower had not had much use and had the right amount of oil in it.
Totally I know they are all rubbish, everything is made in China, but this is the world we created and now there is nothing we can do about it
Posts: 6,938 Likes: 322
G'day all This is an interesting thread because it involves history as it is unfolding.I feel China can make products to any quality chosen. I know they make great China - and have done so for centuries!  In many ways, the market is way beyond any one manufacturer; but every manufacturer must 'fall in line' to remain competitive. My contempt is with respected manufacturers that hide behind a veil. That is, they do not sufficiently control the quality of products they choose to have made in China under the banner of their name. China has very obliging manufacturers that may produce the very best - or the most dodgy. I think there is no case for 'industrial racism'. There is a secondary problem: the advent of the entry-level, domestic lawnmower as a mere appliance - a throw-away job with a limited lifespan. This is relatively new concept in lawnmower history. As such, manufacturers have responded to the 'pizza' market ... but that should not absolve them of a decent base product. --------------------- Jack
Cyber Jack, I agree that the consumers are driving the market and that manufactures are bowing to the pressure instead producing a good product and insisting on a fair price.
I don't think our factory workers along others understand that buying something that last is important than the instant gratification of a cheap unit. They buy and gripe like heck because it is a piece of junk then complain about their low wages. In order for manufactures to pay good wages they must be able to make a profit on what they sell.
It is a ferocious cycle that will only end with everyone being unhappy.
I recently purchase a blown Briggs 09P series engine that had about 30 minutes use. It had thrown a rod. You can not blame it on the engine quality though. The user had ran it without even putting oil in it. On top that this crankshaft and blade was bent. Apparently the users had no business even operating the SP walk behind mower in the first place.
This whole sorry saga has been slowly picking up speed for 20 years, it is only now that we are seeing what devastating effect this is now having on the economies of the previously strong financially stable countries. I see little for future generations to smile at
Victa obsessed
Cyber jack, I agree with what you've said, but sadly most of them are made on a budget like Chinese Briggs and chondas
G'day all This is an interesting thread because it involves history as it is unfolding.I feel China can make products to any quality chosen. I know they make great China - and have done so for centuries!  In many ways, the market is way beyond any one manufacturer; but every manufacturer must 'fall in line' to remain competitive. My contempt is with respected manufacturers that hide behind a veil. That is, they do not sufficiently control the quality of products they choose to have made in China under the banner of their name. China has very obliging manufacturers that may produce the very best - or the most dodgy. I think there is no case for 'industrial racism'. There is a secondary problem: the advent of the entry-level, domestic lawnmower as a mere appliance - a throw-away job with a limited lifespan. This is relatively new concept in lawnmower history. As such, manufacturers have responded to the 'pizza' market ... but that should not absolve them of a decent base product. --------------------- JackAn interesting tangent this has gone on.  Was talking about this with a mate after discussing mowers no less, fairly new to me having my first garden to look after, but he was pulling many apart not so long ago in high school. He then brought up the plastic cams on newer engines. My jaw hit the floor. He's an engineer so the discussion got down to the fact that they have essentially deliberately made design choices based on light domestic use and say a fairly short lifespan, so they've saved let's say $20 per mower by using plastic, this will add up. However they don't seem to be taking into account that once it fails they have done irreparable damage to their brand and reputation and as always it's likely not affordable or viable to fix, cheaper to just replace the whole engine, another sale, yippee. Yet you've got a pissed off customer that's wondering why their dads lawnmower is 30 years old and still goes first pull and their new one fell apart after 5. It is everything these days, see it in electronics where a cheap component has been used for a saving of actual cents, which then fails catastrophically and takes out a device worth hundreds. It is insane. Every corner has been cut, every part has been screwed right down to be as cheap as they can get away with. I am surprised this has not really been covered purely from an environmental aspect, the amount of things these days that are not made to be repaired or not viable or affordable to that end up in landfill, chuck it and buy another one. It's depressing and I can't see how this can continue indefinitely. You do occasionally see those that are passionate about making a quality product and good workmanship but it seems rare these days.
Hi Dooley topics spin around in all directions. My theory for years has been, everybody is running around wanting to lower emissions, how much damage is done to the environment by producing products that will only last a few years compared to producing a similar product that will last many years. Sorry this won't happen because money is the bottom line, not the environment. Think about the Adani coal mine, we can sell coal to India so they can fill the atmosphere with emissions, but we are not allowed to burn it here for our own power. Smoke that goes up in India still travels around the atmosphere regardless of where it is burnt. All about dollars in the end
Firstly, It's interesting to see such a humble subject evolve into an abstract of socio-economics. Sometimes you never know what you'll get when you ask a question !! Secondly the picture solved my problem so ... Lots of luck solving the problems of the world but I'm sure you'll need less luck solving mower problems if you come here.
Cheers to all
Quality is a direct experience, independent of and prior to intellectual abstractions. R. Pirsig .
G'day all
--------------------- Jack What day in history isn't? It evolves and devolves around us continually and, technologically has accelerated since WWII at an almost logarithmic rate. It's a shame that the the sociology hasn't kept up.
It's interesting to see such a humble subject evolve into an abstract of socio-economics. Sometimes you never know what you'll get when you ask a question !! G'day Brycevr
I guess so - though this is not a great example of a moderated topic is it? Perhaps it should have been broken up, and social comment moved to the 'Off Topics' forum.
It is good, though, that this topic solved your engine problem.
My favourite quote must go to Norm ... This whole sorry saga has been slowly picking up speed for 20 years
I feel we are all now like governor springs: always under tension, always being revved up!
Posts106,837
Members18,196
