0 members (), 10,553 guests, and 631 robots.
I have a Honda Harmony HRB215HXA, Engine GXV140K1, which I purchased in 1997, and it starts and runs faithfully after 19 years, but I noticed oil leaking from around the flywheel recently. After pulling the flywheel off, the top oil seal was sitting low (below the outside metal around it). The compartment with the PCV valve was suprisingly clean looking, but the gasket to that compartment looks a little 'rough'. The disc, the mesh, and the drain hole all look fine. I replaced the oil seal around the crankshaft, thinking that would fix the problem, but it still leaks oil around that area. The new oil seal now sits up level to the top of the metal rim outside the crankshaft,and is very tight. My next guess is to replace the gasket. Any other ideas on what this could be?
The mower has never leaked oil out of the bottom onto the floor.
Thank you for any help you can provide.
Greetings Diane, and a warm welcome to the ODK Forums.
Rather than re-invent the wheel, here are a couple of past discussion threads which address this specific issue in some detail:
https://www.outdoorking-forum.com.au/forum/ubbthreads.php/topics/57948
https://www.outdoorking-forum.com.au/forum/ubbthreads.php?ubb=showflat&Number=55962
For sure, I'd replace the PCV compartment cover gasket, and also check that the small drain hole isn't blocked.
Thank you for the 'welcome' Gadge. I've replaced the gasket to the PCV cover, and problem fixed! No more oil leak! Thanks for the reference to the additional discussion threads.
18,241 Registered Users
Topics12,778
Posts106,882
Members18,242
