0 members (), 9,117 guests, and 622 robots.
I think trying to find an off the shelf fix is not going to happen, something is going to have to be machined up or fabricated. Not rocket science, anything can be done, you just have to find somebody capable of doing it, there are people out there who can do it. Try your local bearing supplier and see if they know somebody who does a bit of backyard machining, they usually do
Yeah but its Kingaroy. Went to buy a new motor today but Briggs don't do an 8.5hp anymore they jump from 6 to 11 and 11 up all have 25mm shafts. The guy said strip the 10hp i have and get the shaft machined. Going to start the strip down tonight and get this thing done.
Ok so it is in Kingaroy, should be able to get it machined for peanuts laugh
lol yeah just moved out here from the rat race. Renting and bought an acre and about to start building. Actually looking forward to pulling the crank out. Done a lot of different motors over the years but never a Briggs. Looks pretty straight forward.
Just as well i checked the 10 and 12 hp motors i have, won't physically fit where they need to be #$@/@#$�@$.
Someone somewhere must have a 8.5hp 22mm straight shaft. They must of used that motor on some type of other machine and not just on the @#$@�@ Yardbug.
Could use the 6.5hp ebay motor, will have a think.
NormK
You might be able to help me out. The 5hp from my Rover Colt 5 fits the Yardbug and Rover made a Rover Colt 8. Is the 5 and 8hp physically the same size motor?. If they are would like to chase up an 8 and get the shaft machined down to suit the Yardbug.
Original smokey, carby problem motor just sitting there with battery and fuel tank removed. [Linked Image]
Original motor with 22mm straight shaft not stepped.
5hp from Rover Colt great fit. If 8hp from Rover Colt is physically the same size would prefer to fit the 8.
This is my problem. My 10, 12 and 5hp motors have stepped shafts, 22 stepped up to 25mm so pulley won't slide up
Top of the pulley. They say they cant hold the big pulley end in lathe, it will wobble, can't machine out because cutter will catch on keyway and break, there wont be enough metal left to deepen keyway if they machine out to 25mm, it is a blind hole and can't do, it's not blind it reduces 70mm down where the bolt comes up from the bottom and screws into the end of the shaft
The pulley that is driving me nuts.
Mower is loaded on trailer ready for the tip. Got a lot of use and very easy to work on and never broke a cable. Will try one last thing, phone MTD and find out hopefully what pulley they were using on the 8.5hp version (if it was stepped 22 to 25mm) and if i can get one.
I posted on the other subject post of yours, re the 8.5HP. There is no reason that it cannot be clamped to the bed of a mill using clamping blocks and then run a 25mm facing cutter down the length of the step. Going from 22 to 25mm you are only removing 1.5mm of metal. It looks from your photo you would still have plenty of metal to rebate the keyway that amount which could be done with a square file or use a slot drill to take it down and then just square the corners out. Norm has offered on there to work the pulley over if you send it to him.
Found a really really old workshop locally.
The guy clamped the pulley in the lathe and kept tapping it till it spun true.
He said he could open it out to 1" but the washer inside 70mm down was an issue making it hard to cut the keyway.
He said he could cut the pulley in half do the machining and then sleeve it back together.
The phone rang it was MTD Australia saying their representive has sent me an email. The email had the part number for later model pulley which is 1" and the original engineering drawings for the pulley showing 1" and the pulley is in stock. Wow its ordered and be here in a couple of days.
Thanks for everyone's patience and advice Thanks
There was always going to be some way to skin that cat
Tryerb, RobHam, Mark Tasmania, Mello Mac, beanbandit
18,235 Registered Users
Topics12,777
Posts106,881
Members18,236
