2 members (looktall, JEH),
7,962
2,567
Hey Guys
Does anyone have a parts list or parts manual for a Greenfield Anniversary 12 32?
Any help would be great?
Also is there any after market greenfield suppliers?
Posts: 310 Likes: 1
PM your email to me and I shall send you the Greenfield 12-32 parts PDF file.
most parts are made only by Greenfield. Bearings, belts, tyres, front wheels, some pulleys are about what you can find after market. or custom fab.
Regards, Paul
Such is life....... Nothing better than a "GreenField" just mowed..
Posts: 1,842 Likes: 14
Yep, the range of aftermarket parts is limited, right enough. To add to SuperDooper's list: blades/bolts, drive chains and small sprockets, and wheel drive clutch cork linings are available through at least one alternative wholesaler [GA Spares]. Their website is useful for cross-referencing Greenfield part numbers with standard industrial designations.
Belts and bearings, and steering rod ends, tend to be standard industrial types on Greenfields.
Cheers, Gadge
Posts: 8,216 Likes: 235
Steering on these is a poor design, in particular the pivot point that mounts up beside the motor
Thanks guys
I have encountered the steering issues. Simple but prone to premature wear. One issue i found was the exhaust cover was pointed directly over one of the steering arms which caused it to heat up and bend under load. Simple fix, remove the cover.
I set that steering pivot up on one using pillow block bearings, but don't go there, the work was massive
Posts106,871
Members18,214
