1 members (Ken Hobbo), 3,233 guests, and 2,036 robots.
#75648 25/05/16 08:14 AM
Hi all I have a Victa 2stroke 550 that screams it tits off. All o rings have been replaced bottom engine seal/bearing have not. Any ideas?
Have you tried another carby on it Heff?
Does it run the G4/LM carby?
If so make sure the poppet valve is set in its right position...
Paul
Such is life.......
Well you sucked me in, I had never heard of an Over Erving mower. Apart from that, can you get to the throttle and check that it is closing at low setting?
If it is a full crank engine a dodgy decompressor can cause over revving as well as a crank case air leak or blocked jet.
If it's a power torque it could be the top starter oring which is common does the engine respond to throttle at all ? Or does it just scream the same all the time
Perhaps the rarest of all Victas.
I will move this topic to the correct form and re-name it shortly.
18,145 Registered Users
Members18,145
