1 members (auProspector),
655
1,931
Hi all, great site you have here!
I have a Power Torque motor (early Chinese) and i cant figure out what is up with the decompressor. The Decompressor itself appears fine, ie. springs open, and when sucked shut and blocked, stays shut with no air leaks.
The motor is currently a bare block, with no carby/hoses/exhaust attached.
Problem is, when installed the decompressor does not function. It appears that the compression from the motor acts on the underside of the decompressor diaphragm, closing it immediately. Within 2 revolutions(~half the cord), the motor becomes very hard to pull through.
I have tried the motor with 2 different decompressors with the same result (one with the restrictor installed) I have checked there is no carbon in the head holding it shut.
Any ideas on what could be causing this behaviour?
Posts: 126 Likes: 1
Have you got the blade plate on? If not that'll be why it's hard to pull it acts as a counterweight
What the hell, it runs!
Posts: 325 Likes: 1
Hi Wolfrt and welcome to the family!
As Michael said above it sounds like either the blade plate is loose/missing OR the crankshaft is bent.
These engines need the blade plate fitted to start and run. if you pull it without the plate fitted it will pull the cord (Painfully) out of your hand.
Pete
Victa rotomo, backfiring,has been rebuilt by a competant man ran well a the start. I gave him new rings the piston to my eyes was shagged,he reckoned it was ok, iam thinking its getting blowby the rings, i am using it to mow, or maybe a carby problem.qu does anyone know where to get a new piston, its pure folly to want to mow with such ancient machine, but i dig it. Any help would be appreciated. Its also a model two
Victa rotomo, backfiring,has been rebuilt by a competant man ran well a the start. I gave him new rings the piston to my eyes was shagged,he reckoned it was ok, iam thinking its getting blowby the rings, i am using it to mow, or maybe a carby problem.qu does anyone know where to get a new piston, its pure folly to want to mow with such ancient machine, but i dig it. Any help would be appreciated. Its also a model two. Sorry i couldnt find where to put new posts.
Blade plate was not installed. Thanks for the help, that was silly of me.
good tip by the other guys . as it is the real flywheel , same for almost any small engine and good it didnt try to start mate . as ihatewetsocks said , it WILL HURT even now when a broken flywheel key it still hurts diognosing  . we all learn the hard way . the flywheel on theses is really only for cooling as not much weight to them so they NEED a steel plates maybe not blades though
Posts: 6,938 Likes: 322
Hello wolfrt and all ContributorsThis is just another example of the experience members bring to these great forums. Thanks to Michael for the first diagnosis, and then to others for support. All very amazing.------------------------ Jack As this topic seems resolved, I will lock this topic.
Topics12,750
Posts106,779
Members18,091
