for my money , i would put a later type filter on it anyway if your going to use it fulltime as they work a lot better , if you have a handle with a hole already drilled it it for a filter up top of them use that and grab a setup off of a later model with a real filter inside .
just use one from a powertorque all of it just take out the cable . not to sure what your wanting too do but if its going to be used , put away the good old choke , use later stuff and it filters better anyway
made the filter out of flyscreen rolled up. I know its a bit rough but seems to work as it should. looking for the powertorque hose with the right angle so i dont have to move its clamp as it is rusted on an can not be moved much. I hope i didnt just confuse yall. Sean
The design is fine, nothing wrong with a bit of initiative. Just make sure you put the internal washer back into the filter housing otherwise that mesh might work its way out and get sucked straight into the engine....:)
And I'd have to agree with The VMan, Maybe throw on a complete power torque unit without the cable, snorkle and all is a good Idea yeah?
thanks Mr 6 , thats what i meant complete snorkle n all the old bushy here had a rover one , works perfect but upto you , easy and it works well . i would show you but seems it wont upload again
ooooh ok , geeeeeez...... good though , i was thinking higher , out of dust but allgood works at least . might like to put a thin wire or cabletie through flyscreen so it stays put hold it in place so it dont get sucked in
