3 members (GFazz, Bruce, Red Rum),
8,013
665
Hi I replaced a new rear carrier on my Victa 550 SP and the strange things happened...
For the normal working condition SP Victa 550, when SP cable is engaged, this stops rear wheels going backwards. What my mower does now, is when I engage SP cable, it stops rear wheels going forward....
I am thinking is there anything I have done wrong during the process of replacing the rear carrier?
Posts: 6,938 Likes: 322
Hello detective007
I don't know this machine at all, but ... Is it possible you have the pawl pinions reversed. There is a left hand and right hand side (?).
Can any member help here?
------------------------------------ JACK
Hi Jack,
Thanks for your input.
What is pawl pinions?
Hello detective 007
When you said you replaced the 'rear carrier' what did you mean? Did you remove the rear wheels at all?
Cheers ------------------ JACK
Hi Jack,
Rear carrier is what rear wheels connect to. Yes I stripped everything apart including both rear wheels
Posts: 715 Likes: 1
seanw
i dont know if i can help but if you post a few pics maybe vvcomm will pipe in. Sean
motorwannabe
Ok. I will post up some pictures tomorrow.
Thanks and Good night.
it sounds like as Jack said , you have reversed the clutches they are left and right , the cog looking parts inside rear wheels it IS easily done as they look almost the same , try just swapping side to side complete . means clutch , key ,washer and all related parts .. meaning all the parts you see when you remove the wheels try to keep them matched up if you did already . its the only thing i can think of right now as its an easy mistake to make . hope it works out for you  , Dave
Thanks vccommYou explained that better than I did. I found an illustration. There is a left-hand and right-hand spring in the drive carriers. Simply swap the drive carrier assemblies side-to-side. This is the most obvious explanation for what you have described. ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2015/09/full-7392-23912-550sp_drive.jpg)
Hi here are two picture on the SP part. ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2015/09/full-9549-23918-2015_09_14_15.06.31.jpg) ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2015/09/full-9549-23919-2015_09_14_15.06.21.jpg)
Hi Thanks for your explanation. I will switch over all relative parts when I have time tonight, will come up here to update later.
Hi I swapped cogs side to side and the SP function works as it should. Yes these two cogs are almost the same by just the looking of them, but they are small difference between them if look very closely, which affects the SP function.
Thanks for your help.
 well done there 007, Q wasnt needed . good you worked it out
Hi Sorry to bother you again. Does the 550 SP gearbox need to be greased?
only if you had it apart , or if your just wanting to check or clean out ? then yup , last one i just used a good moly' type same as i greased my car with , the really messy black stuff seems to stay softer longer doesnt dry up . ps , energrease AO or equivalent so the bible tells me , i just looked  ... so if you like to go by the book there ya go
Posts106,871
Members18,215
