2 members (aitchey, Bruce),
3,659
1,126
Hi everyone, I'm new to the forum after having recently purchased a 20" Scott Bonnar 45. I'm looking to get it back into reliable working order and was hoping to get some advice. My thoughts so far are for the frame to be repainted, reel sharpened, new engine (probably Honda GX120 but happy to take suggestions) and a new catcher. After inspection today, it looks like the reel has taken a hit as a blade is bent. Can this be repaired or does it mean a new blade reel? I've attached a few pics so could you please advise on the sprockets, frame, blade reel, etc to give me a bit of an idea of what I'm getting myself in to. Also, is the conversion from the current B&S 3HP to the Honda GX120 a simple conversion? ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2015/07/full-2772-22831-sb45_1.jpg) ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2015/07/full-2772-22832-sb45_2.jpg) ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2015/07/full-2772-22833-sb45_3.jpg) ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2015/07/full-2772-22834-sb45_4.jpg) ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2015/07/full-2772-22835-sb45_5.jpg) ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2015/07/full-2772-22836-sb45_6.jpg) ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2015/07/full-2772-22837-sb45_7.jpg) ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2015/07/full-2772-22838-sb45_8.jpg) ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2015/07/full-2772-22839-sb45_9.jpg) [/b]Moderator comment: Note only 10 images can be included in one post.[b] Thanks, Christian
Hi Christian, welcome to Outdoorking. Note that only ten images can be included in one post. I've localised the 11 images, because external storage sites delete them after a time, and we need our archives to be permanent. Final image from your post: ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2015/07/full-2772-22841-sb45_11.jpg)
Posts: 6,938 Likes: 322
Hello Christian! Welcome from me too! Thanks to Glo Mod Grumpy for embedding the photos. This machine is the less common 20" Model 45. This machine presents as being in sound condition in terms of the sprockets. I don't think it's had a hard life at all. Yes, the reel can be straightened. That is not a big issue. Advice for sharpening:-[1] Do your homework first. [2] Ensure the repairer is not an agent, but has the specialised grinding machine for the reel and bottom blade on site. [3] Specify new, sealed bearings for the reel [4] Take the reel and bottom block complete to the repairer - meaning, do not remove the bottom blade from the sole plate. Take the bottom block complete. [5] Ensure both the reel and bottom blade (or new replacement) are both ground. Advice for painting:-Other folks on this site should be able to assist with colour. Whatever you do, do not use the powder coat process. Preliminary Advice:-Before you do anything, you must assess the condition of the top rails, the two rails the engine is bolted to. To do this, remove the engine and primary clutch complete. [1] sand the frame rails and inspect for any cracking of the rail. [2] a straight edge across the top will help assess warping (if any). At this time remove the clutch from the engine by loosening the cotter pin nut. The clutch housing should be a firm fit on the crankshaft. At this time, measure the crankshaft OD or clutch housing ID. This will determine the replacement engine. Replacement engine fitting is straightforward. Advice on Engines:-Some folks here have strong Briggs or Honda preferences. [I'm sure they will tell you  ] Either OHV Honda or OHV Intek Briggs will be fine in my book. There are many helpful topics on this site to assist you. The main thing, now, is to disassemble and check the frame for damage. Please report back with your findings. Yours presents as a good candidate for restoration and should give many further decades of reliable service. Hope this helps.-------------------------------- JACK
Thanks very much for the comprehensive advice CyberJack.
I've commenced the stripping of the frame so will post a few pics of the rails tomorrow hopefully, if I get a chance to remove the clutch.
I'm relieved about the straightening of the reel blade. A replacement reel wasn't in my plans.
Also, thanks to Grumpy for embedding the pics in my post. I was all at sea trying to do that.
Cheers, Christian
Posts: 2,998 Likes: 16
Hi Christian,
Just a quick word on Honda engines, they are probably the best power plants available and certainly surpass the old Briggs and Rattlers especially when it comes to the vibration factor, something which is really crucial to the 20 inch Series II model (which is what you have) so as to avoid rail fatigue and eventual failure. The only thing is that most Honda's have and I stand corrected here is they use a 3/4 inch size PTO shaft size and as such you'll probably have to source a new clutch half as the Briggs units are mostly 5/8 inch bore units.
Cheers, BB
Thanks bonnar_bloke for your advice RE the Honda conversion. I measured the ID of the clutch and can confirm it is a 5/8 inch bore. Do you know where I can get a 3/4 clutch half from? Will this half bolt on to the original other half? I've pulled the mower down, given the frame a bit of a sand and the rails look pretty good to me. There aren't any cracks in the areas which I've sanded. CyberJack and others, what are your thoughts? Is this a sufficient inspection? I put a straight edge across the rails and they are fine. At the bottom of this post is a few pics of the frame. In relation to the reel and the bent blade, I'm guessing this should be straightened before powder coating, and after these two steps, the reel and bed knife should be sharpened?? Are you able to make suggestions in this forum for a good sharpening service in Melbourne's west-northern suburbs? If not, no problems. Only early days on getting this SB45 into working order, but quite enjoyable so far. The Scott Bonnar videos on YouTube have also been very helpful. I'd hazard a guess and say the star of these videos is also on this forum, so thanks. Here are the pics: ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2015/07/full-9406-22961-rail_pics_22.1.jpg) ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2015/07/full-9406-22962-rail_pics_22.3.jpg) ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2015/07/full-9406-22963-rail_pics_22.2.jpg)
Hello Christian,
That's a good frame, as most 45s frames still are.
Yes, the reel should be straightened and painted first. But remember, NO powder coating. Conventional painting is the best.
I can't personally recommend a sharpening service in Melbourne. I know ADE use Foley grinders at Cheltenham.
Administrator Deejay is the star of the videos. Hopefully, now that he's back, he will want to say something here.
As to the 3/4 clutch inner half, I'll leave that to member Bonnar Bloke.
Hope this helps. ---------------------------------- JACK
Hi Christian,
As far as 3/4 clutch halves are concerned they are readily available through our online store or other outlets which ever is easier for you.
I must admit I'd really like to see much closer shots around the engine mount holes as I'm somewhat concerned that there are a few fine fatigue fractures showing, but as your shots are not close enough I can't confirm positively.
Could you take some extra shots for me so as to evaluate and then I'll get back to you with a solution to remedy the situation if it's what I think.
As far as Jacks advice on reel damage correction and refinishing I couldn't agree more with his solid advice, especially when it comes to powder coating.
Cheers, BB
Posts: 567 Likes: 2
MOD & GREENFIELD TECHNICIAN
Hi Christian,
Gotta say I agree with Bonnar Bloke. There are some v suspicious marks from the lower holes in the photo. I'd be paint stripping the area rather than sanding as sanding can mask fine cracks. Then a good look with a 10x glass. Reel mowers are not my area of expertise but finding and repairing fatigue cracking in structure is something do a fair bit of. Hope you enjoy your project.
Hello Christian and members, I downloaded the photos and viewed them at your original size: I read these as outlines of the engine base. I guess some surface pitting caused by the close contact of an alloy base with the steel rails over 3 or 4 decades. There is also some pitting from surface rust. I do not see any cracks on this 20" frame. Christian, could you also take a close look at the underside of the rails to confirm you see no cracks. If you do not see any, but would still like a second (or third) opinion, then please supply photographs as suggested. Clutch: The 5/8 DIA clutch half is HERE. The 3/4 DIA clutch half is HERE. The Thrust Bearing is HERE. Either the Briggs OHV or the Honda OHV are smooth, reliable engines. Either would be suitable to re-power your application. Your old side-valve Briggs - by its design - produced more vibrations than an equivalent OHV. They were very good engines but no match for the new OHV designs offered today. The main thing is that you re-power with an OHV design. If your 5/8 clutch is sound, the Briggs would be entirely suitable (and economical). If you would prefer a Honda, make enquiries as to whether a 5/8 shaft is available in AUS. The Briggs, as a full-line engine manufacturer, will offer both sizes. Hope this helps.--------------------------------- JACK
Hi Christian, CJ and prd,
I have to agree with Jack (he has tools at his disposal that us mere mortals don't) that these marks are very consistent with the underside casting profile of the Briggs engine, also with the enlargements of the shots they now show that the marks are very straight lines on both front and rear rails and thus won't be fracture lines as fatigue will normally not create straight line fractures, they will radiate in all different directions away from the mount points.
Personally I think you are one very lucky chappy having a twin rail 20 inch chassis that requires none if any work in this area. Normally most 20 inch machines will have had a flogged out clutch at some point in time which will exaggerate the vibrations from a Briggs engine and thus induce much stress and flex into the longer 20 inch rails around the engine mounting points. I currently have a 20 inch machine the same as yours and it has had two massive rail failures. I will take some shots of it tomorrow and post them up onto this thread just showing what can happen due to lack of maintenance.
I will say that you've got a fairly good canvas (so to speak) to work with as a basis and it would be lovely to see that 3 HP Briggs fully restored and powering that machine again for another 40 odd years.
Cheers, BB
Hi all, Thanks again for the responses to date. They've been helpful. I've stripped the rails further this weekend using paint stripper, where you can see some photos below. The rails look good and I can't see any stress cracks or other deformations. Let me know your thoughts on the rails. I've taken the blade reel to get straightened before painting, so I should get that back later next week, where all parts getting painted will then head off to get sandblasted. Bonnar_bloke, you raise an interesting point about rebuilding the B&S 3HP. Part of me would like to keep the mower in it's original condition, however the mower will be used regularly so I'd like a reliable engine, hence why I was leaning towards a new Honda GX120. If rebuilt, will the B&S make for a reliable engine? ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2015/07/full-9406-23041-sb_rail_holes_4.jpg) ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2015/07/full-9406-23042-sb_rail_holes_3.jpg) ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2015/07/full-9406-23044-sb_rail_holes_2.jpg) ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2015/07/full-9406-23045-sb_rail_holes_1.jpg)
Hello Christian
The rails look fine to me.
I think prd's idea of using paint stripper (rather than sanding) for inspection of Model 45 rails is a good idea. Perhaps that should be the recommendation in future cases. Perhaps Mod BB might have something to add there.
FRAME:- Christian, you've said this machine will get regular use. I made a recommendation for an OHV engine, not on the basis of reliability, but on the basis of preserving the frame.
I do not believe there is any dispute on these forums that some high work hour machines of 17" and 20" sizes have in recent times experienced rail failure. We have no reliable data as to how wide-spread that issue is, or the exact causal factors. Anecdotal evidence is important - that's all we have at the moment - but the years ahead will give us a better idea.
It is, I believe, a vibration problem, as our Engineer Grumpy has identified. The combination of rail thickness specification, combined with the vibrations characteristic of single cylinder side- valve engines is probably the main contributing factor - plus the hours of operation of the particular frame. This is a new issue, only emerging in the last few years.
It would be easy to argue that the 20" frame is more susceptible to failure, given the longer rails. The problem is, though, the 17" machine was, by far, the biggest seller. The 20" machines catered for a niche market of larger residential lawns and lawn mowing contractors. The best advice I can give is to play safe, and opt for a new OHV engine, that has reduced vibration levels.
ENGINE:- The old Briggs engines were super reliable. The new Briggs engines are super reliable, as are the equivalent Hondas. It is really a personal choice here.
The desire to keep the machine in original condition is a good one; but what is in your favour here is the fact that re-powering requires no modification. Returning the machine to original spec. could be done at any time. Again, whether you decide to recondition the side valve Briggs, or re-power is a personal choice.
Hope this helps. ------------------------------ JACK.
p.s. Christian, your excellent photo record of the frame, and the discussion here, will be most helpful to members and moderators alike.
A big thank you to Mod BB and prd for their contributions.
Hi Christian , CyberJack and prd,
I really like the idea of using paint stripper for removing paint without disturbing the substrate underneath, but its a bit of a messy procedure for some as I could imagine.
I generally use a 4 inch grinder with a flap disc on it and that rips everything off and gives a great finish, admittedly not everyone has 5 x 4 inch, 3 x 5 inch and 3 x 9 units all with differing wheels on each at their disposal as I have so using what is convenient to each person will differ. Oh and while I remember I forgot the 7 inch machine in that lot, man too many grinders in my power tool cabinets.
As far as choice of power plants is concerned I totally agree with Jacks idea of of the OHV units opposed to the side valve units. My main concern is that you've gotten an "out of jail free card" so far with those rails and you don't want to start something that requires a whole lot of rework so a newer breed OHV unit such as a Honda would really be a bit of preventative maintenance in the long term I'd say.
I really think that a nice restore job on this unit will have your mower coming into the $1600~$1800 bracket and that's nothing to sneeze at. As Jack has already suggested, it would be easy enough to substitute power plants without having to do any structural changes whatsoever and if you so desire you could return it to original factory specs without a worry in the world.
We'd love to see progress photos of what you are doing as it all helps others and instills huge confidence in new Scott Bonnar restorers that view our forum before tackling any type of work themselves.
Cheers, BB
Thanks to CyberJack, bonnar_bloke and prd for your comments and assistance thus far. It has been really helpful.
I've decided to go with the Honda powerplant for the reasons provided by you guys.
An update on the restoration. The reel has been sent off for repairing the bent blades. It's ready to be picked up, which I will this week. I'll then be taking everything that is getting painted off to get sandblasted.
I'll probably order the motor this week. I know i'm probably over-keen on this front, but it will make a beautiful centre-piece at the dinner table for a few weeks before going to work.
I'll post some pics up shortly when I run into some inevitable barriers.
Cheers.
Hello ChristianThat's good news! Yes. there's nothing like a new engine as centre-piece on the dinner table... A conversation starter ... do that trick with the whipped cream Thanks for the update.------------------------------------- JACK
I thought i'd post an update of how the SB45 restoration is going, since I last posted.
It hasn't progressed a great deal unfortunately due to work commitments, however I have got the blade reel back from having the blade straightened.
Now the reel, frame and other bits will go off next week to get sandblasted, before painting.
I've been having a read on this forum about the best hammer tone paint colour to replicate the original Scott Bonnar green. Galmet Jade Green was suggested. Are there any others?
Also, the disassembly of the mower has gone well to date with the exception of the rear rollers. I was hoping to disassemble the rear rollers completely to enable me to sandblast them and then re-paint, however I have been unable to remove the internal wheel/hub from each roller. There is rust inside the rollers which may be a reason for this, if they are even able to be removed. I will post some photos tomorrow of what I mean as they will provide a much better explanation than my words.
Thanks again for everyone's help.
Hello Christian,
Okay, we'll wait for the photographs. Generally, the rollers should come apart relatively easily.
As far as paint colour is concerned there is absolutely no commercially made paint that comes close to the colour that Scott Bonnar used on your machine. The Galmet colour chip is nothing like the actual colour so please disregard the colour chip you've seen. The only way you'll be able to replicate it is to get a can of "Silver" Hammertone and have it colour matched from the inside of your chain case before you have it sand blasted and that will give you the best result.
Have a look at the machine that member "mikeo" has restored and that's about the best match I've seen on this forum. At this stage we are still hopeful that mikeo can get the actual formula from his paint supplier and share it with us as this will make life really easy for all the new members that come to the ODK forum. BTW there are no records of any of the colours used by Scott Bonnar on file with any of the Australian paint manufacturers and no records from SB have survived after Rover took over in 1980.
Cheers, BB
Hi all, Here are some pics of the rear rollers. A bit hard to see inside them, but rust and other rubbish is present. Should the internal hubs/wheels be able to removed by hand? Ie. without much force? ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2015/08/full-9406-23352-rear_roller_pics.jpg) ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2015/08/full-9406-23353-rear_roller_pic_2.jpg) ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2015/08/full-9406-23354-rear_roller_pic_3.jpg)
Ok, so crisis averted. I got the rear rollers disassembled. I'll clean these up and send them with the other parts to get sandblasted next week. I've been doing some research on hammer tone paint colours and see that PPG do several greens. The hammer tone they produce is called Protec 311. Has anyone had a look at these colours? I was looking to get the paint colour-matched, however the places I have been to thus far don't seem keen to tint hammer tone as it contains silicone. Anyway, I'll go and have a look at these colours and see if any are close to what the original is or if they can colour match. Another update soon. Cheers. ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2015/08/full-9406-23356-rear_roller_exploded.jpg)
Hi Christian, I recently used the Protec 311 on my recent resto and was very disappointed with the paint as a whole. Didn't go on well and had to paint it twice for coverage. Very thin paint! On the plus side they did get a good colour match but failed to note the formula. They are currently in possession of the remainder of the paint in the hope they will be able to advise the correct code.
Hi Christian,
Sorry I didn't get to you sooner but it's obvious that you eventually worked it out. It's amazing what a bit of age and rust can do to make things harder than they seem.
we're still hoping that Mr Jones can get his paint supplier to come up with a formula as that will make life much easier.
I must admit I've had quite a few paint suppliers only too happy to colour match Hammertone paint here in Adelaide. Some suppliers just want your money and aren't interested in doing anything for it as I've found in the past.
Cheers, BB
Hi all, Time for an update... Late last week I received my parts back from the sandblaster. I primed them over the weekend so they are now ready for paint. I'm going with Protec's Olive Green Hammertone. Mr Jones advised that it went on very thin and required two coats. I'll also give it two coats and we'll see how it comes out, in regards to both paint quality and colour. Now on to more interesting news. I've become the proud new owner of another SB45, this time a 17" model. A relative contacted me after hearing of my interest and them and donated one to my cause. In my view its in pretty amazing condition and comes with the original catcher which is dinged up a little, but also a brand new Scott Bonnar catcher STILL IN THE BOX! I'm pretty happy about it. Also in the catcher box was a brand new chain cover and grass deflector. All appear to be genuine spare parts. So my plan is to have this mower as my everyday mower, so will get the reel re painted then grinded with the soleplate/bedknife and get the engine going again. It seems the engine was going a few weeks ago after a long, long time of inaction, but after running for a few minutes it stopped. Does anyone have a procedure I should run through to do some diagnostics on the engine? Here are some pics: ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2015/08/full-9406-23612-primed_parts.jpg) ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2015/08/full-9406-23613-new_mower_1.jpg) ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2015/08/full-9406-23614-new_mower_2.jpg) ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2015/08/full-9406-23615-new_mower_3.jpg)
i am not a reel mower guy ........ but now thats a good looking honest machine !!! congrats on it Christian . engine problem could be its just sucked up some old fuel . clean out the tank and air filter an oil change and see if its ok then . just suck out all the old fuel , i got one of those things from supercheap , was i think $5.00 and its an easy way to change oil too , just tip it a little and suck it out . not much really ever goes wrong with the carby's on them unless they have been tinkered with before its just a matter of using the choke in a way that suits you , pull out and it will fire . push in a little and it should run when its got fresh fuel up . hope it helps a little for ya
It doesn't get any better at that price !!
Hi Christian,
How did you end up going with the 17 inch machine and how's progress going on the 20 inch machine ?
Cheers, BB
Members18,151
