0 members (), 6,608 guests, and 1,445 robots.
#6401 20/10/07 05:36 PM
hi bruce
a mate of mine has this generator carnt see the make or model its about 15 years old is on a house boat its electric start it has this cast box on the engine which has the points and condenser in it but the problem is after a while the spark jumps across from the points to the cast box and cuts the engine out the mechanic comes out and changes the points and condenser and its ok again for a couple of months and then the same thing happens what would cause this to happen so often
mattauto #6402 20/10/07 07:34 PM
mattauto,
Ok the easy way to fix your problem is bypass the points and condenser with an electronic module. The problem I think will be moisture.
Can you post a picture so we can see the motor. cheers2
Bruce #6403 20/10/07 10:05 PM
bruce thanks for your quick reply i carnt get you a picture wont see it for a few weeks and was hopeing to have it fixed. i through the same thing would i get a electronic module from a lawn mower place or would the module have to suit that motor
thanks
mattauto #6404 20/10/07 10:33 PM
mattauto,
Can you call the guy that replaced the points and condenser and find out if he knows the engine model. cheers2
Bruce #6405 22/10/07 12:31 PM
bruce
the generator is a onan mcck series marine generagor can you please tell me what sort sort of electronic ignition module to get thanks
mattauto #6423 25/10/07 08:44 AM
mattauto,
This Module should do the trick. cheers2
Bruce #6466 01/11/07 07:14 PM
thanks bruce
mattauto #6506 10/11/07 11:11 AM
Victa Mower Specialist
mattauto,
How did you go with your module. Did it work? as I have done the same thing on a Briggs & Stratton motor and I am interested about what happened with yours. rolleyes
Victa Man
Bruce i havent done anything about gettin a electonic ignition module as yet and i was wonding if you had anymore i could buy
thanks
mattauto #6878 16/01/08 10:07 PM
mattauto,
Yes I still have some of the modules left. Just send me a PM. cheers2
Bruce #6883 17/01/08 11:06 AM
sorry but i dont no what a pm is
mattauto #6896 18/01/08 09:12 PM
If you click on my name you will see a drop down list which will have in it PM private message. cheers2
18,156 Registered Users
Members18,156
