1 members (Bruce),
1,960
1,700
Posts: 510 Likes: 1
Not sure how this will be received. But, I am putting together an ultrasonic cleaner. Thought someone may be interested. I don't clean a huge quantity of carburettors, but I want a more passive way of doing it. I also want to limit my exposure to carb cleaner. I could have just bought one, but what I have noticed is: a cleaner advertised as 100W, may be 50W heating & 50W ultrasonic power. So adverts can be deceiving. I got the idea of using an old deep fryer from "Roebuck". Cheers, it should work a treat. So for $2 at the recycle centre, here it is. The kit I bought is a generator circuit card and 2 x 50W 40kHz transducers. Basically, 240 Vac supplies the board. The output from the board powers the 2 x transducers that get attached under the cleaning vessel. ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2015/05/full-4730-21815-ultrasonic_1.jpg) The Card I mounted up in an insulated enclosure. I'm not sure how it will work when its finished, but I will let you know.
Posts: 585 Likes: 8
great job .will watch this one with interest.
What did the ultrasonic kit cost? Any benefit in attaching four transducers? Please keep us updated...
Are you using the deep fryers heating circuit? And if yes, won't it get too hot for the carbies? If no, are you supplying a heat source as well as the ultrasonics? Very interesting project, would like to know about the transducer kit as well.
Posts: 510 Likes: 1
Hello fella's,
Diesel, the kit cost $65. The generator board I have will power 2 x 50W transducers for 5 mins on, 5 mins off to cool down, I will install a 12V computer fan to keep it cooler and increase run time, maybe. It will have its limitations.
You can have as many transducers as you like, but you will need a generator board that can power them. The price for those goes up.
Trev, I am not having a heater at all. I have never used one of these before, so I will see how it goes using hot water from the tap.
Hopefully it will turn out to be something I can use. Cheers
Hi
I purchased a ebay ultrasonic cleaner some time ago, a 12 litre for $400 i think. It heats and I use it a least twice a week, works great. I had some posts on the machine on the forum some time ago with the results.
I'll follow this thread with interest as the kit you using is somewhat cheaper than the commercial unit.
I find 65c is a good temp to work at, as a hot water rinse after cleaning it all flash dries.
Posts: 4,291 Likes: 4
Pardon my ignorance,as I have never used anything like it before,but what do they do? Is there any real practical use in cleaning mower parts? Sorry guys I have herd of them but my lack of knowledge now has me intrigued.
Link to two old ultrasonic cleaning threads, they have some before and after shots. I find the cleaners are excellent at cleaning carbies and other parts that have intricate and hard to get to spots, like air bleed galleries, jets, emulsion tubes etc etc. Strip down, dunk them in and come back 1/2 hr later, rinse and reassemble. 1st old ultrasonic cleaner thread and 2nd old thread
Posts: 510 Likes: 1
What do you think Blumby, about the cleaning results.
Thanks Rusty ute, I have seen one of your threads before, not the Suzuki carb one though. 65 deg C as a good temperature, nice to know. Your machine does a great job, it is the cats pajama's.
Hard to see what heatsinks are being used on that board from the photo but it should be fairly easy to put bigger heatsinks, and make sure to use black ones rather than plain aluminium for better heat transfer and a longer duty cycle. Make sure you use some heat transfer paste if you change the heatsinks as well. I'd also use a much larger enclosure to allow more air flow with your computer fan idea.
Posts: 510 Likes: 1
Some things for me to consider there, Trev. Understand emissivity of a black surface, to better help heat transfer. I have some large heat sinks here. I might fit them down the track. Also have transfer paste. Just want to get it working to start with.
Often wondered why the heads on engines are not coated with a heat resistant black finish.
Hi Mark. I came across a similar looking board with similar specks from an English supplier and they claim 45 minutes on 20 minutes off as a duty cycle so I would imagine with better heat sinks and better cooling yours should be able to match that.
Mark Electric....re your enquiry on heads being painted with heat resistant paint, it may be that the paint may inhibit heat flow to the cooling air, forming an insulating barrier and increasing head temps. I remember from my misspent youth playing around with high performance VW air cooled motors that even a single coat of paint would increase temps by 15-25 degrees....just a thought
Posts: 510 Likes: 1
Trev, so with larger heat sinks, larger enclosure, computer fan, I could possibly run this for a 30 min duty cycle? I would work up to this, monitoring temps as I go. Was the board you looked at powering 2 x 50W units?
Diesel, What about an anodised black finish on a Victa power torque head. Not economical to do, but should give a cooler running engine.
Quite a large area when you start reading about emissivity of black bodies. Black coloured car radiators, heat sinks, fighter planes and more.... Thanks
Yes, it was for two 50 watt units Mark. I emailed the company and they confirmed the duty cycle. Yours may be a chinese copy of theirs, assuming yours is chinese that is.
Will add significantly to cost with no real world improvement........?
Posts: 510 Likes: 1
Worked on this today and got it to the point where I could test it. Energised it to give it a few short runs. Worked fine, you can see the high frequency vibration in the water. However, the fuse on the board blew. I mocked up another fuse, but the board has no output. So this project is on hold. ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2015/05/full-4730-21869-wp_20150521_003.jpg) ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2015/05/full-4730-21870-wp_20150521_004.jpg) ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2015/05/full-4730-21871-wp_20150521_001.jpg)
Posts: 1,842 Likes: 14
Mark Electric....re your enquiry on heads being painted with heat resistant paint, it may be that the paint may inhibit heat flow to the cooling air, forming an insulating barrier and increasing head temps. I remember from my misspent youth playing around with high performance VW air cooled motors that even a single coat of paint would increase temps by 15-25 degrees....just a thought Yep, the paint does act to reduce heat transfer, to the air flowing past the fins. It adds a 'thermal resistance' to the system, in effect. Anodised finishes on aluminium don't have the same effect; they're really only a dye added to the oxide layer on the surface of the aluminium. The oxide layer is made a bit thicker than natural by an electrolytic process, and the dye is adsorbed at the same time. Anodising can be done as DIY, but that's only really practicable for small parts, as it does require a DC power source. Caswell Plating supply suitable dyes for this process.
Cheers, Gadge
Posts: 510 Likes: 1
Thanks for that Gadge, I had a look at the video on Caswells site, the 5 step process is quite involved, requiring tank heater, filter pump and a kit of chemicals and more...
Where my cleaner is at: new board and repair parts for the damaged board are on their way. Why it blew the fuse could have been my fault, I had the tank half full of water, around 4lts plus the basket. The fuse blew when I removed the basket. I have learned that with out a load in the tank the output current increases making the heat sink hotter. Should have had the tank full of water. Does this ring true for anyone?
I have learned that with out a load in the tank the output current increases making the heat sink hotter. Should have had the tank full of water. Does this ring true for anyone? Being an electronics technician since 1967 and having worked on a lot of high frequency stuff, I really cannot see anyway that could be true. Transducers are in practical terms simply a speaker albeit generally using a ceramic disc as the driven element rather than a coil of wire. I cannot conceive of a change in load causing a change in current unless there is an electrical circuit between the ceramic and the metal of the tank that could slightly change the capacitance and even then I would consider it highly unlikely. Is there electrical contact between either of the terminals and the body of the transducer?
Posts: 510 Likes: 1
Ok, Trev, Thanks, I will do some measurements and let you know. It maybe the way I have attached the tranducers to the tank. they must have good contact, pretty sure that is OK. All is good, should be able to get it working.
Posts: 510 Likes: 1
Results of transducer testing: No connection between the centre (positive) contact and earth when disconnected from the boards output. (as expected)
When transducers are connected to the boards output, there is about 0.3 Ohms to earth. (this doesn't sound right to me).
The outer contacts on the transducers (negative) are connected to earth, very low resistance reading 0.3 Ohms.
I will compare these readings to the new board when it arrives.
I didn't do solder connection to the transducers, as 250 deg C max is recommended. I was going to use heat sinks and solder them, but ended up connecting them with small nuts and bolts.
What is the reading to earth at the board without the transducers connected Mark? Given there is an earthed contact on the transducers, it seems likely to me that removing the basket with the circuit active may have caused an earth loop somewhere. You may have come across an earth loop sometime in audio equipment where too many earths can cause a loud hum in the system. An earth loop can cause quite high currents to flow which may have blown the fuse/board components.
Posts: 510 Likes: 1
Trev, The board is short to earth. Cant get back to this for a few days, Thanks for lending your experience to this.
Without knowing for sure the circuit configuration it sounds like the output semiconductors have blown. If they have, and they blew due to a change in current in the circuit due somehow to removing the basket, I'm guessing they are probably FETs which are very prone to that type of failure. (Don't know your background but in case it isn't in electronics as such, FET is Field Effect Transistor.)
Posts: 510 Likes: 1
Thanks Trev, This where it is at: supplier sent new board & parts for cost of postage. I replaced the board and ran it for 5 mins, no problems, with tank full of water. When I fitted the lid with the fan. The card failed again, no output. The heat sink where extremely hot, lid on or off. I then replaced the failed components & disconnected one of the transducers. I have been running it for durations of 30 mins now, with no problems. I also added pieces of additional heat sink to each switching device, using screws and transfer paste. My conclusion, This board will only power one transducer. Don't put it in a small box, even if you have a fan. Heat sinks get too hot causing switching devices, transistors, what ever they are & diodes D4 & D5, fuse to fail. ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2015/06/full-4730-22179-wp_20150606_003.jpg) ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2015/06/full-4730-22180-wp_20150604_006.jpg)
Do the transistors and diodes have numbers on them Mark? It may be possible to replace them with higher rated ones of the same type but you need to know what the specs are of the originals first. A lot of manufacturers will remove the numbers so that people cannot easily copy their design.
Posts: 510 Likes: 1
Thanks, I will buy some to have a spare board on hand.
Failed diodes D4 & D5 (FR15 with RG underneath) Failed Transistors / FETs Q1 & Q2 (brand name is a lower case f, the numeral 6 in the centre, K41 with J1 3007-2 underneath) Guess I should try to find components with a higher heat rating)
I was wondering how you set the fan up Mark. Suck or Blow? And did you put other holes in the case to allow flow through? You should be able to google the part numbers and find the specs on the semi conductors. I figured given how easily the outputs failed they were going to be FET's, notorious for being hypersensitive to any sort of load fluctuation.
Posts: 510 Likes: 1
Trev, I had the fan above the heat sinks, sucking air out of the box. I did drill many small holes in the enclosure, enough so that the fan motor wasn't working hard. I have ditched the fan for now and have the board in a larger box cooling naturally.
I am looking for a board that can supply the 2 x 50W transducers easily.
Topics12,747
Posts106,768
Members18,074
