0 members (), 11,911 guests, and 818 robots.
#62452 05/03/15 08:32 AM
Hi all. I've taken a pretty significant nick out of the bottom blade hitting a rock the other day. Resulting mow is now leaving a deeper cut on one side. Probable reel damage but I'm yet to take a look. Can the bottom blade be replaced and if so approx cost? If I need to replace the reel does the 45 17 inch fit the 430 diplomat. If the reel is bent can it be reshaped?
Thanks,
Pete
Hello tiger99!
This is every reel mower owner's worst nightmare. It's not uncommon.
There are two things working in your favour:
- the bottom block's captive washers may have given way.
- the machine offers reel protection via belt drive and springs.
In these cases, if the reel is not damaged, the most damage will be
the set has been compromised. Nothing more.
If there is damage to the bottom blade, then back-lapping may fix it.
What we need is for you to investigate the problem and supply us with
photographic information.
To answer your specific questions:
- the bottom blade is replaceable. Cost via ODK on-line store.
[NOTE: if bottom blade needs replacing a sharpen & set will be required]
- I do not believe the 45 and 430 reels are interchangeable.
- The reel can be re-shaped, but this depends on the damage encountered.
I hope this helps.
JACK.
18,157 Registered Users
Topics12,759
Posts106,814
Members18,157
