3 members (looktall, thomas18, MowingManiac), 5,356 guests, and 1,673 robots.
#61934 15/02/15 07:52 PM
GRB
Offline
Does anyone have a easy way to remove the clutch from the motor shaft? Iv tried opposing leavers and giving the end of the crank shaft a solid hit with a bronze drift and hammer. Tried tapping the housing to loosen it. Am I missing something??
Hi grb, I am having the same problem as you trying to get the clutch off. The pin near my motor is a rusted in
Hello GRB and Joeyvek,
I'm sure we can help, but we need more information.
I'm not sure if either of you are speaking of the Model 45.
WE need some good photographs thanks.
In the meantime, here is a 45 primary clutch removal guide:
https://www.outdoorking-forum.com.au/forum/ubbthreads.php?ubb=showflat&Number=39040#Post39040
JACK.
I will have to take a few pics and post them. I have a 1968 Scott bonnar 45 with a solid deck. And the engine number I think is 61202. Which from what I have read us a 2 hp engine. My captive corer pin is rusted in and does not have the nut on the top
If the crankshaft is rusty, it will have expanded in diameter - rust is much bulkier than the same quantity of iron or steel. When it expands into the bore of the clutch, the two parts become locked together and are not all that easy to shift. I suggest you proceed as follows.
1. Separate the two halves of the clutch, by removing the three screws around the perimeter.
2. Remove the engine, complete with attached engine-side clutch-half, from the mower.
3. Soak the crankshaft extension and the bore of the engine-side clutch-half in Penetrene for a couple of days.
4. Use a fairly large 3-jaw gear puller to push on the end of the crankshaft whilst pulling on the outside of the clutch-half. Apply a fair amount of pressure then tap the clutch-half axially with a hammer, working around the outside of it. Then tighten up the draw bar again and repeat.
If you do all of this carefully, you will not damage the clutch-half.
GRB
Offline
Thanks Grumpy and CyberJack.
18,191 Registered Users
Topics12,766
Posts106,828
Members18,192
