1 members (MowingManiac), 10,373 guests, and 104 robots.
#5960 28/06/07 06:41 PM
gac
Offline
I have a McCulloch chainsaw which I have just received back from my son in law after an extended stay.(not working)I have pulled it down and beleive it can be ressurected with some new parts e.g.plug,air filter,clutch, and new fuel lines.Iam not sure of where to go to price parts and if it will be worth the effort in the end.Can anyone give me some guidance?It is a Titan 50 model #60015209 around 10 years old.
gac #5961 28/06/07 07:53 PM
gac,
I will check to see if the parts are still available tomorrow.
Here are the part numbers:
Clutch 235115
Air Filter 228892
Fuel line 235713
Vent line 235741
Spark plug you will be able to get from your local mower shop. cheers2
Bruce #5962 29/06/07 07:16 PM
gac
Offline
thanks for the quick response.If available can i order trough you?
gac #5965 30/06/07 07:50 PM
gac,
Only one parts is available at this stage and that is the air filter. cheers2
Bruce #5966 01/07/07 06:52 PM
gac
Offline
Thanks again for your help.I bought fuel line and a spark plug this weekend,replaced all fuel and oil lines,reinstalling springs in those lines with them.Cleaned up magneto and I am getting a great spark but the thing refuses to fire.Doesn't seem to be dragging the fuel up to the carby.Seems to still have good compression but maybee not good enough.
gac #5967 01/07/07 07:02 PM
gac
Offline
Attempting to revive a McCullock chain saw.Bought and replaced fuel lines and spark plug this weekend.Great spark but the thing refuses to fire.Doesn't seem to be getting fuel.Can anyone shed some light on why not?Compression seems good but maybee not good enough.Fuel lines are clear and filter in tank is clean and clear.Any clues would be greatly appreciated
gac #5968 02/07/07 12:01 PM
Gac,
Replace the fuel filter in the tank and remove the muffler and have a check to see if the exhaust port is clear of carbon.
Then try to start without the muffler on. If it starts then you could have a blocked muffler or screen in it.
Also check for scoring on the piston & cylinder.
Try this stuff first and let me know be fore we further. cheers2
Bruce #5974 07/07/07 10:58 AM
gac
Offline
Hi bruce,
Just got back to playing with the saw this morning.Did as you said and still not firing.Can't really see any major scoring of the bore,looks good in fact.But thats only comming from an untrained eye.Is it possible to stuff up the timing by removing and replacing the magneto coil in the wrong place in the cycle? Also is it possible to check compression easily?Rings maybee?
gac #5976 07/07/07 12:44 PM
Gac,
I don't think it is the rings at this stage from what you are telling me.
1. Did you put the key back in the crankshaft where the flywheel goes?
2. Did you reset the air gap with a business card?
3. If you put your finger over the spark plug hole and then pull the starter to see if you get any signs of compression.
4. Are you getting fuel(is it fresh) to the cylinder (is the plug wet)?
5. If not try putting a small amount down the plug hole and see if it fires at all.
6. If it fires up then we go to the next stage carby.
Answer these questions and then get back to me with the answers. cheers2
Bruce #5978 08/07/07 11:41 AM
gac
Offline
Bruce,
I tried everthing you said this morning.Plug is not wet so its obviously not getting fuel.Compression seems resonable with a finger over the plug hole.Didnt take the flywheel off (realised after that this would be the only thing to upset the timing).Fuel directly in the head produced a great result fired a couple of times.Carby blocked somewhere?The old lines fell apart in my hands.
Thanks again for your time,
Regards Greg
P.S Any luck with parts?
gac #5979 08/07/07 04:59 PM
Greg,
I can get the air filter but the other parts will take some time to get.
1.You will need to replace fuel filter (in tank) fuel lines and carby diaphragms. Once you have done that I am sure that you will have a good machine. cheers2
Bruce #5981 09/07/07 09:09 AM
gac
Offline
Can I assume you can source these parts for me?The only thing I will need to get it going,(besides air filter and now carby diaphrams and fuel filter)is the clutch.I purchased new fuel line from the local mower guy.Dear as poison.I have the 3 clutch segments but the spring is broken.Can that just be replaced?While I am at it I may as well fit a new bar and chain. Are they still available?
Thanks again for your patience,look forward to your reply, as always,
Greg
gac #5982 10/07/07 12:26 AM
Greg,
The bar and chain you can get from your local mower shop (after market type). The carby diaphragms can also get from your local mower shop (max cost $20.00).
The fuel filter in the tank you can use an Oregon type (Cost about $8.00 max)
The clutch springs that will be a bit harder but I am sure that you could get after market springs again from your local mower shop. McCulloch part number 227360.
If you want I can supply the parts that you need but they will be after market. cheers2
Bruce #5983 10/07/07 08:45 AM
gac
Offline
Once more a big thanks, will let you know how I go.
Regards Greg
gac #5987 13/07/07 09:31 AM
gac
Offline
Hi bruce,
I have struck a brick wall up here as far as the clutch goes.My local guy says I am wasting my time and that clutches and /or clutch springs are no longer available, "may as well throw the saw away"!!. I can get a carby kit,new bar and chain ,fuel filter and air filter but all to no avail if I can't get a clutch spring. I have been to 2 spring suppliers up here who will gladly make me one for "around $150", and they have nothing off the shelf to suit.I have been to several mower places and all are not even interested in trying to chase one for me,"absolutely unavailable"I'm told.The spring seems to be a seperate McCulloch part on its own. Any clues as to where else I could chase one down????.
Regards Greg
gac #5997 19/07/07 11:25 AM
gac
Offline
Could anyone out there tell me where i could get a clutch spring for a Mcculloch Titan 50 chain saw? Its all I need to get a good little saw back in action.Could another brand be substituted?I can post dimensions if needed.
Gac.
P.S will be on holidays for 2 weeks from the 20/7 but eagerly await any responses.
gac #5998 19/07/07 03:17 PM
Victa Mower Specialist
Gac,
Can you post a picture on the board of the clutch and old clutch spring? rolleyes
Victa Man
gac #6001 20/07/07 09:00 AM
gac
Offline
Not sure how to go about that???.I am on holidays from today and won't have acsess to a computer until the 4/8/07.I will attempt to get a photo on as soon as I am back.
Thanks for your interest,
Greg
gac #6046 08/08/07 10:01 AM
yes it is worth the trouble
gac
Offline
hi hotsaws,bruce,
Just back from os and keen to get this saw up and going.Not sure how to send a picture to this site,just tried looking in the pictures section and it doesnt seem to want to let me post a photo.I am able to email photo's to individuals adresses if this is allowed???Can someone give me some clues as to how to post on this site??
gac #6051 08/08/07 11:57 PM
Hi Gac,
Here is a link on how to upload pictures that should be of help. Google Pack
Bruce #6054 11/08/07 06:42 PM
gac
Offline
Bruce,
Great photo programme but the instuctions don't actually tell me how to get them into this website.Any further instructions?
gac #6055 11/08/07 09:53 PM
Gac,
Use this area Chainsaw Pictures to upload your pictures.
1. Click New image at top of the page.
2. Type in subject and description.
3. Click Image Manager.
4. Click Browse to find file on your PC
5. After selecting File & add caption for file
6. Then press add file.(you can load upto 3 files)
7. After file upload is finished then press Done adding Files.
You will then go back to where you started and all you have to do then is click Submit.
Bruce #6060 16/08/07 06:47 PM
gac
Offline
Was the clutch photo any help??How about you victaman??
GAC
gac #6063 17/08/07 04:06 PM
Gac,
Have located the clutch. I have sent you a PM regarding the price. cheers2
gac #6071 21/08/07 09:32 AM
Hi Gac You can email me a pic and repeat the model No of the saw to niteglo@vic.australis.com.au and I will have alook for you . Got a few bits and pieces kicking around the shed Regards Joe
Joe
Hi Replying to myself here???????? I se there is a pic posted of the clutch needed and I will print it out. Just been looking to post a new topic but cant see where to start . I have put a really good Scial 2 chassis etc on Ebay Model 562 just to see if there was any interest etc Aso a 160 engine from same job I wanted to startanew topic but just cant seem to find my way around this site so good as the old one Cheeers Joe
Joe
Hi Gac Sorry but no joy on the clutch or spring for it Have just discovered the other pages and see that Bruce has found a clutch so all is well Cheers
Joe
Joe I have located the clutch.
Bruce #6075 21/08/07 06:33 PM
gac
Offline
Thanks for your interest anyway Joe.Always appreciated.
Gac
Moderated by  Bruce, Mr Davis
18,147 Registered Users
Members18,148
