2 members (Telly, vandea05),
5,313
123
Posts: 113 Likes: 2
Hi all, My neighbor gave me this Mc Culloch blower and I need a few parts for it but I can't find any model number on it. Any ideas please. ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2014/10/full-8388-17978-13102014066_1.jpg) ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2014/10/full-8388-17979-13102014067_1.jpg) ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2014/10/full-8388-17980-13102014073_1_copy.jpg)
Posts: 113 Likes: 2
The pictures loaded ok but they are not showing now.
What am I doing wrong???
Edit: seems to be working now :)
Hi Buckets, Just change the Markup in the panel just below the posting box, click on the drop-down arrow and choose "Using UBB Code" Your pics will then appear in 'Preview and your post. Easy-peasy!
Posts: 113 Likes: 2
Deejay, if I am looking in the right place there is a drop-down box that says using HTML but there is no using UBB Code.
Under Quick reply it says HTML is enabled - UBBCode is disabled.
Regards
Buckets
Posts: 113 Likes: 2
Hi all, just wondering if anyone knows how to repair a plastic fuel tank.
The hole that the fuel line goes through (it's on the top of the tank) is not air tight, so that when you tip the blower forward fuel runs/dribbles out.
I was thinking of a rubber grommet but can't find one small enough, or a larger piece of fuel line, but then it's to big to go on the carby pipe.
Thoughts?
Are there two lines going to the tank, a fuel and a return? I have used a 19mm holesaw in a cordless drill to make a hole to take a standard brush cutter fuel grommet when I have had a similar problem and it worked fine.
Posts: 113 Likes: 2
No she is a golden oldie, only has the one line from the tank to the carby.
So it will be like a chainsaw set up then rather than a brush cutter. Try and find a piece of fuel line that will slip neatly over the existing one and drill the hole in the tank out to be a tight fit for the larger line so that the larger line acts like a grommet.
Posts: 113 Likes: 2
Thanks aussie,
that worked a treat.
Topics12,777
Posts106,879
Members18,228
