2 members (shjump, noileg), 2,743 guests, and 2,283 robots.
#5787 28/04/07 07:25 PM
This has the Tillotson carby. Problem starting. Have cleaned carby and replaced carby diaphrams. Has new spark plug with good spark. Have put in new fuel. Starts for abt 2-3 seconds then dies. Fuel is getting to carby. What are the best positions for the 2 screw settings and which screw is which?
Any other ideas on how to keep it going?
Wreader,
When you replaced the diaphragms did you replace the fuel filter screen in the carby? confused
Yes
Warwick
Wreader,
If you did replace the scree in the carby and not just the one in the tank. bigshock
Here is some information on the setup:
Setting up your 2-cycle Tillotson Carburetor.
Before mounting your Tillotson carburetor check the pulse track from the carb mounting surface and make sure that this track through the carb adapter , gaskets and etc is clear and in line with each other. bigshock
Set the low (Closest one to the cylinder) speed needle at 1+1/2 turns out and the high speed needle at 1+1/8 turns out. yay
Hope that this will be of some help.
I will be loading up some information regarding carby setup procedures in the future into parts list and manuals area. cheers2
Warick,
I have just uploaded the information on the Tillotson carby into the parts list and manuals area. cheers2
Thanks Bruce
I have made a contribution so I can view the Parts List area. Where do I find it on the Board?
Warwick
Wreader,
If you can not see the parts list and manual area just refresh your browser. cheers2
18,147 Registered Users
Members18,148
