2 members (DFB, auProspector), 2,205 guests, and 1,895 robots.
Hi
I ma looking for either a manual or other assistance so I replace the Engine Cork Clutch on my Scott Bonner 45.
I have no idea where to start1
Ronbrisbane
Hi Ron, welcome to Outdoorking.
I suggest you begin by reviewing some past threads:
https://www.outdoorking-forum.com.au/forum/ubbthreads.php?ubb=showflat&Number=49306&Searchpage=1&Main=8596&Words=%2Bcork+%2Bclutch&Search=true#Post49306
https://www.outdoorking-forum.com.au/forum/ubbthreads.php?ubb=showflat&Number=47417&Searchpage=1&Main=8345&Words=%2Bcork+%2Bclutch&Search=true#Post47417
If you have questions as you read them, just post them here. Our SB45 guru, Deejay, is interstate at present but posts as often as he can.
Hi
Thanks for your response.
I am however confused.
When I took the outside casing covering the gear area I found cork at the bottom of the casing.
It appears however from where you have directed me that the cork is in the middle of the drive shaft that controls the spinning blades. So how it got into the casing is a mystery!
So now I am totally confused as the blades are spinning fine.
When however I try and engage the self propelling drive by squeezing the handle I initially had some drive but very little.
I then discovered the bolt that adjusts the leaver for the handle.
When I initially adjusted it the machine took of like a rocket then stopped half way through mowing.
Are you saying that all the transfer happens in that centre gearing area and that it is not just the engagement of the cutting blades?
Sorry for the long question just trying to understand.
Ron
Thanks Again Guys
You are very helpful!
My Scott Bonner has a brass identification plate marked Mower Number 45 11361
Does that identify when the mower was made I would be interested to understand that information?
Any ideas how I can discover that?
Ron
Ron, we don't know of any way to date the mower from its serial number. Our SB guru, Deejay, believes that the numbers were not orderly and no records of numbers have survived. If your mower has a Briggs engine and it is the original one, give us the Model, Type and Code numbers (stamped on the cooling air cowl) and we can tell you when the engine was manufactured. The mower will have been made several months later.
18,091 Registered Users
Topics12,750
Posts106,781
Members18,091
