2 members (looktall, DeanVR4), 6,028 guests, and 1,194 robots.
Hi i have this mower and it doesnt start, there is no compression, pulling the cord its too easy but dont hear any air leaks. Removing spark plug piston is still connected to con rod.
I can turn cutting disk easily on all pitson cycles with spark plug tight ion place with my little finger.
need manual for rover B&S 4hp 4 stroke mower
dristo72,
It sounds like the valves are not seating correctly. bigshock
The steps that I would take first are: woot
  • 1. Remove the muffler
    2. Remove the valve cover (two screws)
    3. Check to see if you have valve clearance.
    4. Remove cylinder head.
    5. Remove valves.
    6. Check valve seats.
    7. Reface valves & Seats.
    8. Reassemble & reset valve clearance.
Check this first and let me know what you find. yay
The workshop manual is quite large for the Briggs & Stratton motors and it will take some time before I can upload it to the board. sleep
If you have a look at posts you will find a link to parts manuals that I have put up on oner of the recent posts. That will give you some idea of assembly etc. cheers2
i agree with bruce on this it sounds like a valve not seating correctly the sign of ring trouble is oil on top of piston if no oil is on top of the piston then the compression problem is on the valves in case it is valves your local auto parts place should have valve lapping compound and a valve grinding device they may need to be resurfaced into the seat just a little air leak around them valves will cause problems .
hope this helps you
Calvin
Calvin,
He could also have a loose valve seat causing problems. bigshock
Have you ever come across loose vale seat as I have over the years? confused
Thanks for your input lawnmowertech it is greatly appreciated by members and myself. cheers2
Hi Bruce Loose valkve seats ........ Years ago common problem on Kirby motors Turner were using at on stage .
Bronze valveseat would pop out and no compression etc Pull over engine and the seat will drop back in place and engine run but in the end the seat will pop out again Many agood job done with the centre punc.............. Cheers joe
Joe
worked out to be cyl head gasket, thanks guys
18,159 Registered Users
Topics12,760
Posts106,815
Members18,160
