0 members (), 1,079 guests, and 1,687 robots.
Page 3 of 4 1 2 3 4
tiger #49213 07/09/13 07:09 AM
I still can't get away from a fuel blockage. Have you checked the filter on the fuel tap,inside the tank? Maybe that is blocking the flow of the fuel. I think somebody should do some changes here as this topic was started in the wanted section,but has become a diagnosing and trying to fix topic.
Blumbly #49217 07/09/13 08:19 AM
On the face of it, it would seem a blockage but I have cleaned the filter on the fuel tap. Upon turning the tap, the petrol flows freely. Happy for this post to be moved into a more suitable area.
tiger #49221 07/09/13 12:42 PM
If it were a blockage it wouldn't be flooded
tiger #49225 07/09/13 02:40 PM
Good point. That leaves compression, have started to take off head but one bolt is difficult to get to, no room to get a socket into.
tiger #49227 07/09/13 02:57 PM
The motor will need to come off the base to remove cylinder
tiger #49228 07/09/13 04:05 PM
Originally Posted by tiger
Originally Posted by Bruce
Tiger,
Check the condenser because sometimes under load they break down. cheers2
Condenser looks clean and still getting blue spark, how do you know when they've broken down?
The condenser breaks down under load and you would need a tester to see if it is damaged. I don't care how new it looks it is the internal that could be the problem. In the past I have taken a new one off the shelf and it has been faulty.
What basically happens is that the engine will start and then within seconds the engine will run rough and can stop.
Unfortunately you are in the process of elimination trying to find the issue because you don't have the equipment for testing. cheers2
tomo4192 #49229 07/09/13 04:30 PM
How did I know you were going to say that.
Bruce #49230 07/09/13 04:31 PM
Tiger,
I have a multimeter, is that sufficient?
tiger #49231 07/09/13 04:42 PM
Tiger,
Not really because it does not show under load. The price of a condenser is only about $7.00. Also does the points have any pitting if so that is a sign that the condenser could be faulty. cheers2
Bruce #49232 07/09/13 05:14 PM
No pitting, just curious as to what tool the pros use to test a condenser?
tiger #49235 08/09/13 04:54 AM
Have opened the Mayfair up and checked the bore, it is pristine except up the top where there is some very light scoring. It has not been re-bored. All suggests that the compression should be ok except that one of the rings has got a bit of movement. It's also definitely a 125 cc motor.
tiger #49236 08/09/13 05:01 AM
hey thats good news so far ! can you remove the rings and take a photo to post up.
ill send you a set of std rings i have here.
also once you have removed them sit them in the cylinder so you can see the ring gap and take a photo of that also
tiger #49237 08/09/13 07:54 AM
Great Tomo, I'm guessing that I need to separate the cylinder from the crankcase on this mower so I can take the piston out?
tiger #49247 08/09/13 10:18 AM
Hey , yes you will to get to the piston
tomo4192 #49254 08/09/13 01:07 PM
Took the engine apart. The gasket b/w the cylinder and the crankcase showed a little bit of leaking, not sure if that is a problem and whether that would compromise the compression. Attached are photos of the piston and rings. Put both rings in the bore to show wear, the top ring had a gap of 2 mm, bottom ring was about 1.8 mm. Other photo shows how loose one of the rings was on piston. [Linked Image]
tiger #49256 08/09/13 01:45 PM
For a true measurement of ring gap try a bit further down the bore from the top where it wears most, at most the rings should have 0.432mm ring gap and at least 0.203mm of gap evidently they are very worn, but very cheap to replace, even if new rings didnt come right within spec they would help the situation for a display/light duties mower anyway.
tiger #49259 08/09/13 02:00 PM
Hard to tell from those pictures but do the rings appear to be the same thickness all the way round? Also what condition is the bore in? May just come down to a very good clean.
#49260 08/09/13 02:03 PM
Thanks Joe, if they are very worn it makes me wonder how the compression gauge recorded above 70 psi, anyhow will try to take a measurement further down. I know they're pretty worn because they came off the piston pretty easily.
Blumbly #49261 08/09/13 02:05 PM
Pretty constant thickness all the way around, bore is very good condition, are you saying to just clean the piston grooves and the cylinder bore?
tiger #49263 08/09/13 02:10 PM
Heck yeah I'd even go to the trouble of honing the bore.It would certainly help.
Blumbly #49264 08/09/13 02:17 PM
Can't hurt so will do, have a honing gadget with 3 stones here somewhere, think I bought it do brakes but never used it for that purpose.
tiger #49266 08/09/13 03:07 PM
hey there ,
those rings are rooted ! that gap is rather excessive a hone and some new ones certainly wont hurt it. ill post the hose and rings on Monday man.
should make a fair difference, give your piston a good clean , a light wet and dry to tidy up the scoring , and clean the ring gaps out, base gasket weeping is okay they don't often blow out base gaskets.
a light hone to scuff up the bore and and a good clean , also clear any carbon build up in the exhaust port.
tomo4192 #49268 08/09/13 03:29 PM
Thanks, Tomo, I guess I'll need two gaskets, one for the head, the other for the crankcase, I'll pick those up at the mower shop, is there anything else I need? Do you think the worn rings account for all the problems I've had with this mower?
tiger #49269 08/09/13 04:06 PM
hey , yes you will require top and bottom cylinder gaskets that is about all.
by the looks of the rings there is a chance they are causing the issue , ive replaced rings in better condition that have caused issues, your symptoms and previous diagnostics's points to them.
cheers mitch
tomo4192 #49275 09/09/13 06:14 AM
cheers mitch
Thanks Mitch, just thought i'd ask the question since i have now taken the machine apart so if there was anything else i needed to do eg bottom seal then i' d do it now without having to dissassemble later.
tiger #49281 09/09/13 09:28 AM
If you wish to change bottom seal now is the time if its
soft and clean i wouldn't worry about it
tiger #49282 09/09/13 10:47 AM
Its soft and dry, there was some leakage between the crankcase and cylinder though.
tiger #49284 09/09/13 02:00 PM
sounds okay to me man , id leave it be
tiger #49292 10/09/13 09:52 AM
Noticed that on the bottom ring there is what I thing is called a ring expander, it's a corrugated foil-like object, does that stay or is it removed when I put on the new rings?
tiger #49296 10/09/13 04:05 PM
they normally dont fit with new rings and does no harm not being there , if the new rings dont come with them i normally don't worry about it
Page 3 of 4 1 2 3 4
18,068 Registered Users
Topics12,746
Posts106,765
Members18,069
