1 members (MowingManiac), 3,610 guests, and 1,380 robots.
#48266 09/08/13 04:47 AM
Hi People, needing help. I have a John Deere ride on with a Kohler 4 stroke engine Model: CV155, SPEC:41562, ( sorry that's all the numbers I could find). Long story short am unable to get it to idle properly, have checked & cleaned carby, reset governor and tried adjusting throttle cable, but to no avail. Any help or ideas greatly appreciated.
Hi Paul, welcome to Outdoorking. I think that will be a Kohler Command CV15S, not 155. It should be an OHV vertical crankshaft single cylinder engine of 15 hp. Here is the full workshop manual for it:
http://www.kohlerengines.com/onlinecatalog/pdf/tp_2339_d.pdf
Usually the best way to start an investigation like this if you have the workshop manual, is with the manufacturer's troubleshooting chart, which is on page 21 of the manual. It reads as follows:
Engine Will Not Idle
1. Restricted fuel tank cap vent.
2. Dirt or water in the fuel system.
3. Faulty spark plug.
4. Idle fuel adjusting needle improperly set.
5. Idle speed adjusting screw improperly set.
6. Low compression.
7. Stale fuel and/or gum in carburetor.
I assume you have checked obvious things like that the air cleaner element is clean, the idle speed screw is adjusted to give 1200 rpm idle, the engine is warm, the choke is completely open, and there is plenty of clean fuel in the tank. You also need to check the tappet clearances if your engine has adjustable clearance (some of the Kohler's do, some don't). Refer to page 137 of the workshop manual. Check that the flywheel key is in place and is not sheared (a sheared flywheel key will result in incorrect ignition timing).
Have you checked the vent in the fuel tank cap? Just loosen or remove the cap, and see if the problem gets better or goes away. Have you properly cleaned the fuel tank and fuel line? Water can cause this type of problem. Next, try a known good spark plug (usually a new one, though it isn't that uncommon these days for new plugs to be defective), and set the gap correctly to 0.040" (1.02 mm).
After that, if you have a Walbro carburetor, turn the idle mixture screw (there isn't one on the Nikki) clockwise until it bottoms lightly on its seat, noting how far you have turned it. If it is a long way different from 1.0 turns, try it at 1.0 turns, which is the standard starting point for making that adjustment. If the best idle turns out to be at a lot more than 1.0 turns, there is reason to suspect an obstruction in the idle system.
If you get that far and have not found the fault, it will be time to talk about additional tests. Please post some pictures of your engine and tell us specifically what is wrong with the idle (rough, varying speed, won't run as slowly as 1200 rpm, etc.)
Hi grumpy, thanks for getting back to me so quick, sorry I didn't, been flat out. Will try all that you have suggested in the next day or two and let you know how it goes, if no good will send some photos along as well.
Thanking you Paul.
Hi Grumpy, thanks for all your help, mower running like a dream. Put in a new spark plug and recleaned carby which made me think of filter in the fuel tank and guess what, full off gunk.Thaks again for your help,
Paul.
Thanks for reporting back, Paul. Dirt or grass in the fuel tank is one of the common causes of mower engine trouble. I use a funnel with a fine mesh filter in it for refueling, and never leave the fuel tank cap off unless the funnel is in place and I'm actually pouring fuel. Haven't had any problems since I started doing that. I won't talk about my experiences prior to doing it though.
I'll close this thread.
18,147 Registered Users
Members18,148
