1 members (Ken Hobbo), 3,233 guests, and 2,036 robots.
Found these 'instructions' while browsing the web
Easy 7-step guide to changing your own blades
The first challenge is gaining access to the blades of the mower that normally remain hidden from one�s view. One has to lift the body of the machine-upto see the blades to be able to unscrew the nuts and bolts and remove the blades.
Action the following step-by-step guide prior to unscrewing your blades:
1.Remove spark plug from the body of the lawn mower.
This disables the machine from starting-up during the process
2 .Empty the fuel tank.
This avoids spillage during the changing of lawn mower blades
3.;Try lifting the body of the lawn mower using the limb of a tree and a rope.
This enables the machine to be at a height suitable for you to work beneath, enabling easier access to your blades
4.;Wedge a piece of wood in between the blade and the body so as to safeguard and fasten your work area.
This avoids the risk of blades moving in the opposite direction when applying force. This will fix the blade you are working on to stay in a particular position.
5.Use a wrench.
Turn the nuts anticlockwise to remove the blades
6.;Once you have opened the blades, replace them with new blades
7. Tighten the screws through clockwise movement of the wrench. Do not forget to use the wood-tip once again to allow you to tighten the blades.
Tighten the screws A SECOND TIME
WTF
Life is Hard at the top
Holy Sh&t, Its never as easy as "Use a wrench", but i dont know if these instructions have simplified the process, or if they've made something relatively simple a lot harder...i particularly like the bit about hoisting it up in the air using rope and a tree...lol.
Oh ok so now I know what I'm doing wrong. I'm not lifting the body of the mower with a tree and a piece of rope. How silly of me to forget. Don't surpose I could do that with an approaching thunder storm,could I? I wonder if somebody did that and had a mower fall on them? Hope that wasn't on a manufactures web site.
LOL...now that would be hard to explain! bigshock
Moderated by  CyberJack
18,145 Registered Users
Members18,145
